and i mean when the car is hot, not the engine. when the weather gets above 80 the car won"t start.
cranks fine, no spark though
it turns over fine, it just doesn't fire.
btw
i've already replaced the cap,rotor,coil, and ignition module. my next guess is a starting relay that has cold solder joints. where is the relay(s) located? i'm guessing that they are in the car. since it's when the car is hot and not the engine, when it won't start.
tia, wiley |
main relay is most likely to be to the left of the inside fuse box bolted to the side wall ,mid way up
Pete |
Read this thread on page 5 or 6:
2.2L engine: Warm motor restart problem You do have spark but the main relay is not supplying power to the fuel pump. That's why the motor will stumble sometimes when it first happens. The main relay is located up underneath the left side of the dashboard, way up above the cruise control box. My problem WAS also heat related. Cost: about $95 at a higher quality parts store. Bring your old one in to match the numbers because there are multiple numbers that will appear for that part. My parts guy crossed referenced the number to get the right one. Easy to do yourself if you are a contorsionist and have a 10mm socket with a long extension. Skinny hands also help (you know what that means). Don't spend a dime until you replace this part. It is a very common problem. Good luck. |
2.2L engine: Warm motor restart problem: Thread date 6-27-03
another vote for main relay.
![]() www.cb7tuner.com <---90-93 accord board :for sale: left and right motor mounts for 4th gen accord. great condition :strut bar, rear..no brace... ... |
is it just a little bigger than a match box?or the bigger one?
tia, wiley |
it says i think mitsuba main relay assy or something. has a connector maroon and a grey housing. connected and mounted to the upper areas...its small iono how small though
is this it?
if ur talking about the main relay yeup sure is. good find.
it's only $46 at foreigncarpartsonline.com
sounds like another good find? |
