Old 07-12-2003, 11:12 PM
VSTT VSTT is offline
About Custom Body Kits
I have been looking all over, and want to know, what exactly do I use to make a custom body kit for my revell honda civic si, and how exactly do i use it.
If you got a web site with info on it, plz lemme know.
I have tried to use squadron's green putty (didnt turn out to be so good).
Thnx.
Old 07-12-2003, 11:58 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Your squadron will be handy, but not for the frame of it. A lot of members here use styrene plastic sheets as a skeleton, then 2-part epoxy putty for shaping. The squadron will help for fillling in cracks/holes/joints. Refer to the FAQ at the top of the page for more information.
Old 07-13-2003, 09:30 AM
BugZilla's Avatar
BugZilla BugZilla is offline
Authorized Vendor
I use a product called Castilene. It works like clay, but if you want to take a break and it hardens, just use a hair drier or another heat source and soften it up again. It works like a charm unlike the epoxy which is not all that bad, but if it hardens before you are done , well its a bit harder to work with.
Now I don't know about using Casilene for a permanent fixture. I have dropped it off the workbench when it was hard and nothing happened to it, but on a hot day it might soften up on you. I cast all my work in resin when I'm done, so I haven't worried about it too much.
Old 07-13-2003, 10:30 AM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
-Henry-
Old 07-13-2003, 11:06 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Tamiya putty is what I use, and I don't really have any trouble. I know a few other people from this forum use tamiya putty with no problems.
It may also be helpful to do a search on it, using the Automotive forums search feature, the issue has been discussed quite a few times before.
Good luck!
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
