99 Intrigue not starting when hot!
We have a 99 6 cyl Intrigue. When it is hot out and you run for a while then park it, it will not start again until it sits for three or four hours. Help!!!
I had a similar problem with my 92 Sunbird (also GM). My car wouldn't even turn over when hot, and if yours does not either, it might be the starter solenoid. When the GM starter solenoid gets hot (with an hour or more of driving in my case) the solenoid cannot work properly until it cools. The last straw in my case was when I was stuck in front of a pump at a gas station in Mesquite, NV in August. I finally took it in and replaced the starter. Apparently, some shops can replace just the solenoid, but I chose to replace the whole starter for the warranty. If it is the same problem as mine was, I would recommend some sort of warranty because after I sold the car to by brother-in-law, he had to take it in again (3 years later) for the same problem. Hope that helps.
Is this a no spin or a spins and won't start problem?
If it is a no spin problem, its going to be battery or starter related. If it is a spins and no start problem, its going to be related to fuel or ignition. when the car acts up, remove the 2 plug wires on 1 coil and spin it over and see if you are getting spark jumping between the coil towers. Is this a 3.5 or 3.8?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
