Old 07-12-2003, 10:05 PM
bsting bsting is offline
Headlight Beam Adjustment
Does anyone know the correct procedure for aligning the headlight beams to the right toe-in angle and beam height?
I hate people who decorate their cars with stuffed animals, specifically Loony Toons or Winnie the Pooh. It is NOT attractive or cool. In fact the two words that come to mind are retarded and queer.
Old 07-13-2003, 09:00 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
do you have your owner's manual...it has a good description in there..........otherwise..if you look closely at your headlights, you will see there is a hole where you can insert a long screwdriver to turn a sprocket(use a phillips)
ITR inside
