Old 07-12-2003, 07:13 PM
newbreed newbreed is offline
Send a message via AIM to newbreed
Angry Damn thing wont start!
HIya all. I have a 1985 Pontiac Trans Am, 5 Speed, 305 engine. The car runs like a charm when it ran. =0( The bird is my play toy so its not my primary source of transportation. The damn thing has sit 4 about 2 weeks and wont start!!! It sat for a week and a half and I had to jump it off to get it running and drove it around for a while. When I try to start, it sounds like it wants to for about 2 or 3 seconds then drowns out like a bad battery, but I have a brand new battery, and even a jump start. We have also tried pushing it down the road and "Popping The Clutch" with no such luck. I am a Firebird fan through and through and refuse to give up on this beauty! Anyone here got any ideas? I also tried cleaning the carb and now contemplating a new starter (but it should start without a starter if I pop the clutch, right?) PLEASE HELP!
Old 07-12-2003, 08:22 PM
Blue02R6 Blue02R6 is offline
Well, as my old auto shop teacher used to say, "You need fuel, air, and spark to make it run." So check the filters first. Then check your plugs, and for fuel flow. Without knowing more I can't really say what it could be.
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
1969 Pontiac Firebird
I might get my '02 SS back....
Old 07-12-2003, 10:29 PM
Marc04's Avatar
Marc04 Marc04 is offline
well, you said its an 85, so its an older car, i would look at the fuler fliter, because on my 1992, it was never changed, and would cause the car to surge a little because it was very cogged up with shit, if you blew on one end, air wouldn't come out the other, so i would check that out,
and buy a code reader and see if the computer throws and codes
Old 07-12-2003, 10:31 PM
Tercel GTS Tercel GTS is offline
Send a message via Yahoo to Tercel GTS
does it spin really fast? you may have jumped timing
click to chat at StonerScript
Old 07-13-2003, 06:47 AM
What are you refering to with the word "it"?
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
Old 07-16-2003, 04:24 PM
fyrbyrd80 fyrbyrd80 is offline
Send a message via Yahoo to fyrbyrd80
I would lean towards an electrical issue. Is it draining the battery in between start-ups? You may have a short somewhere.
TBoyer
1980 Firebird 400
Old 07-16-2003, 06:52 PM
Aggrivating Pontiac...
Its sounds like a (almost) dead battery. When I turn the key, It sounds normal for 1/2 to 1 full second then slows down to a stop. In the past, it has always sounded like it has had a hard time starting, but always started. Now it doesnt =0(
Old 07-17-2003, 02:39 AM
It sounds like a battery. What is the voltage from it? If it reads less than 12V replace the cables, and if that doesn't work check the alternator. However if it reads 12V try it in another car. You'll know then if it's the battery.
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
why the thing wont start again toni irene Windstar 3 07-05-2007 10:44 PM
damn thing wont start squibb94tbird General Discussion 6 01-30-2005 09:08 PM
The Thing wont START Claytonias Accord/TSX/Accord Hybrid 0 09-05-2003 01:21 PM
