Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 11-18-2001, 08:26 PM
ToeJam's Avatar
ToeJam ToeJam is offline
Send a message via Yahoo to ToeJam
Questions about "Come-A-Longs"
A winch isn't in my plans, but I'd still like to have a method available to extract myself or another rig in case of an emergency. I've seen the come-a-longs in the past and I know a couple of people in the PNWX club have talked about them, but does anyone have one?
Toss me your knowledge please. I don't know what brands are the best or even where to purchase one. I'm guessing a 8-10 ton model is the best to account for a safety factor.
Old 11-18-2001, 10:27 PM
Kerensky97's Avatar
Kerensky97 Kerensky97 is offline
Don't get one.
I had one and used it once to get out of some mud.
Imagine having a winch line 4000 lbs taut and then grabbing it and pushing and pulling on it with all of your might.
After my one experience I was scared into not using it ever again.
A much better thing would be to bring some friends to yank you out, or if you're all alone bring a folding shovel and dig yourself out. A snapped line through the midsection could put a damper on your whole trip.
-Dustin
2000 Nissan Xterra XE, Sport Package, 4X4, Automatic.
And yes its better than yours.
Old 11-18-2001, 10:35 PM
O1SalsaX's Avatar
O1SalsaX O1SalsaX is offline
Send a message via AIM to O1SalsaX Send a message via Yahoo to O1SalsaX
Talking Come-A-long
I had an experience using my Come-A-long. It wasnt with my X, but with my 1990 S-10 Blazer. We were playing in the sand near me when I hit some loose sand and the Enforcer M/T tires didnt help me out. They just dug, really well. I buried it to the framerails. After Several hours of jacking it up, putting stuff under a tire and driving a foot in reverse, we noticed that my 4 wheel wasnt worknig at all!! So, after a little crying, we hit the Home Depot and bought two tow straps and a come-a-long.
It took us a half hour of work to get the entire truck out. We spent about 3 hours digging, 3 hours jacking up the truck and putting boards under it, and a half hour with the Come-A-long. It worked fine for me. Its in the Back of my X now, Just in case the S*** really hits the fan, last ditch effort. It was $40 and saved me about $300 for a recovery/tow.
Well worth it when used properly...I stress properly..
'01 Salsa X XE
Bone Stock, No really.
Old 11-18-2001, 11:54 PM
Kennedy Kennedy is offline
Never heard of an 8-10 ton come a long...
Here's the one I reccomend, but be careful.
http://www.izook.com/reviews/mppuller/mppuller.htm
Old 11-19-2001, 11:12 AM
coolerman's Avatar
coolerman coolerman is offline
Cool
If you follow the same rules for hand winching as you do for electric winching you will be safe. I have used a hand winch called a Red Devil for over 25 years. It is a 4000 lb unit with a snatch block. Cast Iron! It's heavy! I would never leave home without it. Even when I finally get my Mile Marker installed it will come with me. There are just too many uses for it.
A Hi-Lift Jack can also be used as a hand winch. I tried mine out. It does work but is very slow compared to the Red Devil. You can only winch about 4' (I have the 60' Model 604 Hi-Lift) then you have to reset. The Red Devil has 50' of cable on it
Other things to get: Tree saver strap, 3/4" shackel, gloves.
Old 11-19-2001, 06:22 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
I know a winch looks expensive, but having control of the line inside your truck, while you're maneuvering out of the situation is awful nice. There were a couple of times that I needed to be in the truck AND controlling the winch together to get out of some tight spots.
If I bought a come-a-long (and I still might) it would be to lock down (in an arcing motion)the rear of my truck to keep from sliding downhill or something while winching up front.
Xterra4x4.com and the Xterra Offroad Webring
Old 11-19-2001, 08:03 PM
rhombus's Avatar
rhombus rhombus is offline
I will be adding a More Power Puller to my list of recovery stuff.
Even with the winch up front I have had a few times that I have needed other methods.
Once was clearing a trail. There was a huge dead tree blocking the path and a combination of HighLift w/JackMates and chains made short work of it. There was no easy way to use a winch from one of the trucks.
rhombus
SOXC Member
http://www.soxc.org
Old 11-19-2001, 10:37 PM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Smile Hey Rhombus!
I am glad to see that someone else has invested in a "jack-mate" Very handy tool to have with your Hi-Lift! You can get a Jack-mate here at a good price.
http://www.central4wd.com/store/brandlist.asp?ID=862
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 11-19-2001, 11:40 PM
rhombus's Avatar
JackMates are awesome.
For the tree removal we used two of them.
They just make it so easy to work with chains.
I think that anyone that has a high-lift should consider getting one.
Yes they are expensive but to me worth it.
rhombus
SOXC Member
http://www.soxc.org
Old 11-20-2001, 08:41 AM
Toy Man Toy Man is offline
AF Premium User
More Power Puller
I have the 2 ton More Power Puller. Haven't had to use it yet but it is a very impressive piece of equipment.
