Old 07-12-2003, 03:10 AM
Never Enough Power Never Enough Power is offline
Question SRS Light
Was installing a turbo timer in my gs-t and poked the SRS wire with a test light. The SRS light is now on. I have tried unplugging the battery to reset the computer, to no avail. The dealer wants $80 to reset the computer. Any way I can do this myself?
Old 07-12-2003, 03:20 AM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Damm , you coulda popped the airbag doing that. You basically got lucky. Unplugging the battery shoulda reset the ECU. Depends on how long you did it for. Try pulling the plug for about an hour , and also step on the brake pedal. Its good way to get rid of any leftover charge in the system. Also try unplugging the SRS altogether. You may have damaged the airbag activation or grounding circuit by probing it. And next time leave the YELLOW wires alone.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 07-12-2003, 09:05 AM
Battery was unplugged for about 1/2 an hour and I did use the brake to drain any extra juice in the system. Haven't tried unplugging the SRS altogether, though. I'll see what happens, thanks.
Old 07-13-2003, 11:10 AM
kjewer1 kjewer1 is offline
AF - Advisor
SRS system is seperate from the ECU. So is the ABS. They have thier own controllers. But thats about all the info I can offer
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
