Old 07-12-2003, 12:53 AM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
Angry How do u remove fingerprints?
F***K!!!I was just about to finish my ITR when I accidently touched the roof of my car with a paint laden finger! Now there's a black fingerprint on my roof. How can I remove it without painting the body again? HELP PLZ!!
Current Project:
Fujimi Veilside Combat Silvia S14...almost finished
Old 07-12-2003, 12:58 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
A light sand with very fine sand paper, and a polish should get it out, or even just a polish should work.
Good luck.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 07-12-2003, 12:59 AM
DJ RaYgU's Avatar
But wont that scratch up my body tho?
Current Project:
Old 07-12-2003, 01:01 AM
Michael Schumacher's Avatar
Michael Schumacher Michael Schumacher is offline
Send a message via AIM to Michael Schumacher
Thats why you polish it after the sanding.
He won at the real Nürburgring where the real men race - David Hobbs
Old 07-12-2003, 01:02 AM
Jonno's Avatar
How dark is the finger print? You should be able to just polish it out if it isn't too dark.
Old 07-12-2003, 01:26 AM
DJ RaYgU's Avatar
polish with compound? I dun have dat stuff cuzz the hobby shop i go to doesnt stock dat stuff. All i have is model wax - will that work? The fingerprints are a little dark. U can notice it from up close but not from afar.
Current Project:
Old 07-12-2003, 01:29 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Wax is not abrasive, so it won't remove it. If you can tell us what the body paint is, and the paint on your finger is, that could help.
Old 07-12-2003, 01:34 AM
DJ RaYgU's Avatar
The body is TS-26 Pure White and the paint on my idiot finger is testors flat black enamel. I was just finished with painting the trimmings when the accident occured.
Current Project:
Old 07-12-2003, 01:37 AM
hiver77's Avatar
hiver77 hiver77 is offline
normally a cotton bud wetted with enamel thinner would zap the finger print without damaging your body coat since it's lacquer.
But I have had times when it "dulled" the glossy lacquer surface... dunno
Just polish it again though
In the finishing stage:
Old 07-12-2003, 01:42 AM
Old 07-12-2003, 02:09 AM
Alien's Avatar
Alien Alien is offline
on laquer you could use a mild automotive compound or maybe some toothpaste
Old 07-12-2003, 07:08 PM
hiver77's Avatar
Well luckily I put on the disclaimer word "normally"
Just today I applied some model master acrlyic cleaner to clear up my panel-line washing on a glossy lacquer surface. It removed some of the clear coating and exposed the pearl body coat underneath.
I don't get it... My lacquer surface has been dried for a week and all polished to a nice shine. Here came the evil acrylic thinner (which supposed to be the wimpiest of all) and ruined it
Old 07-12-2003, 07:27 PM
Yikes. Avoid using acrylic thinner on the body, and instead use some windex on a q-tip to remove the paint.
Old 07-12-2003, 11:50 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
windex? Fo reel?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-12-2003, 11:56 PM
Originally posted by CamaroSSBoy346
windex? Fo reel?
Fo SH0 MaNG!!!
