Old 07-11-2003, 04:10 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Help with my amp...
I've had this amp sitting in my basement for a few years after my sister took it out of her Blazer, and I want to install it in my Sedan, but I'm not quite sure how to wire it... It's an MTX Thunder 4320. It looks like it's a 4-channel amp, but I only want to use it to power my two subs. So, how do I go about bridging it, and what settings should I use for the Gain, EQ, and FREQ? It has different Gain, EQ, and Freq. settings labelled "front" and "rear"... I'm totally confused.
Any help would be appreciated.
Old 07-12-2003, 09:42 AM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Maybe this will help you!
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 07-13-2003, 09:17 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I can barely read it, but on the bottom pic it tells you EXACTLY how to hook it up for bridged operation
Old 07-13-2003, 03:07 PM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
If your talking about #51, at the bottom it only shows a 2 channel amp wiring diagram. It doesn't show how to wire a 4 channel down to 2 channels, much less a 4 to 1 channel if the amp is capable. A 4 to 2 is basically the same as bridging a 2 to 1. You bridge 2 channels together to one speaker, and you bridge the other 2 to the other speaker. As for the different gains, eq's, and freq. settings, it's because the amp is made to handle door speakers as well, if you use the amp for that. Since you're not, then most often you'll find that channels 1 and 2 are controled by the front, and channels 3 and 4 by the rear. So if you bridge one sub across 1 and 2 you can adjust the gain..etc. by the front controls, and then bridge the other sub across 3 and 4, you control it by the rear controls. As for the 4 to 1 channel, I don't know exactly how to do this, and I don't want to tell you wrong and mess something up. Maybe Paul D can answer that question for you. Good Luck
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Old 07-17-2003, 04:10 PM
ci5ic's Avatar
Well, what I ended up doing was just using the "rear" inputs, and the "Rear" outputs and it works fine... Figured since there's no signal to amplify on the "front" channels, then all the power would be going to the "rear" channels...
Anyways, put it in, wired it up, here's the thread with pics if anyone's interested... My second time installing an amp, and I think I did a decent job:
http://www.automotiveforums.com/vbul...hreadid=118550
Old 07-17-2003, 05:46 PM
AKKORDINGLY SICK AKKORDINGLY SICK is offline
ok u should have 2 cables runnin from ur deck for the sub that are for the front an rear, since its a four channel amp front an rear should have four holes for wires, since u only have two u have to get this wire adapter that converts the 1 wire in two so both front an rear are all hooked up,
as far as wiring goes just remeber to take pos an neg from one sub nad hook it up to pos from ur lef channel an neg from ur right an do it to both channels
if that made any sense it should be hooked up right
