Old 07-11-2003, 02:33 PM
jackacc's Avatar
jackacc jackacc is offline
d15b swap ??
I know, I know!! If you are going to swap...make it worthwhile but I have a line on a d15b SOHC Vtec from a 93 civic for a steal... I really cant afford to do a b16 swap. I just bought a 5 speed 91 lx tranny to replace my 4 speed... and I have been dealing with my 60hp STD for long enough so ANY increase in HP will help.
Question- Will the d15b motor drop right in without much modification? Are the mounts different? And will my tranny bolt up? I am limited in the funds dept so I just wanted to find out how big of a project it will be and what I will have to change.
Thanks!
Old 07-11-2003, 02:35 PM
SiZ's Avatar
SiZ SiZ is offline
Man, you can get an A6 from somewhere for like no more than $200..
Ya, it will swap in fine but I TOTALLY don't understand why bother..
"The nympho of info, I'm fuckin' what ya heard"
Old 07-11-2003, 02:36 PM
jackacc's Avatar
really? Will the a6 drop in without too much trouble? Where can I get one that cheap? And what kind of hp does it put out?
Thanks!
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
It bolts to your tranny rite up with no problems. Its just like swapping the v-tec. Go to www.fourthgenhatch.com on the how to section for the wiring part. I'm guessing you are getting the vx motor? Someone fill in the rest cause i'm in a hurry!
Old 07-11-2003, 02:37 PM
mellowboy's Avatar
Thanks!
Yep str8 drop in. Its much better than that d15.
Old 07-11-2003, 02:47 PM
GTA's Avatar
GTA GTA is offline
Whee..
depends on if its the sohc vtec-e out of a VX hatch or a JDM d15b sohc vtec. The vx engine only puts out 92 while the jdm d15b sohc vtec puts out 125-130 just like a z6
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-11-2003, 02:50 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Here's where I look when I have horsepower/torque questions:
http://www.automotiveforums.com/vbul...threadid=70346
Flunky
Old 07-11-2003, 03:37 PM
jackacc's Avatar
Yeah this is the jdm d15b sohc vtec, that is why I thought it would be a good alternative. (almost double what my car puts out now)
But my main concern was if it will drop in without modifying too many things and if it will bolt up to my 91 lx 5 speed tranny.
I did not see specs for the a6 engine on that site. ??
Which motor would be the easiest swap:
this jdm d15b sohc vtec or the a6??
Thanks!
Old 07-11-2003, 03:40 PM
GTA's Avatar
GTA GTA is offline
Whee..
Thanks!
easiest is a6. its 108hp. The d15b you'd have to wire in vtec.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-11-2003, 03:47 PM
jackacc's Avatar
Yeah, I didnt think about that (vtec) that could drive up the cost.
But it will bolt up to the tranny no problem? any mounts to change?
Thanks (sorry for the 100 questions...just anxious to buy something while I have the money....finally)
Old 07-11-2003, 03:52 PM
GTA's Avatar
GTA GTA is offline
Whee..
tranny will bolt up. You use the drivers side mount bracket from your car.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-11-2003, 03:58 PM
jackacc's Avatar
Great! Thanks all,
1 more question and I am out.
Does the a6 come with mpfi? Or will I have to worry about that as well?
Old 07-11-2003, 03:59 PM
GTA's Avatar
GTA GTA is offline
Whee..
Great! Thanks all,
if you buy a complete engine the stock a6 comes with mpfi, so you would have to wire that up
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-11-2003, 04:04 PM
jackacc's Avatar
Awesome, definately a must have.... I was thinking about swapping MPFI onto my car as is (and I'm sure it would make a huge difference)
But my motor has 185,000 on it so I figured I should look into replacing the motor before I go through the MPFI swap and have the motor blow.
Now I just have to find a complete a6!!
Old 07-11-2003, 04:09 PM
kapt kapt is offline
Send a message via AIM to kapt
sohc motors make me sad but i understand how it is having limited funds. gl w ur swap.
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
