Old 07-11-2003, 01:37 PM
robmcd16's Avatar
robmcd16 robmcd16 is offline
Send a message via AIM to robmcd16 Send a message via Yahoo to robmcd16
Question Help with engine code....
The code I'm pulling from my stock 97 Civic LX (non-Vtech 1.6) is:
System Too Lean - Bank 1.
Does anyone know what that can be? Whats happening is the car is stalling when it should be idling and I'm burning way too much gas.
I'm leaning toward the O2 sensor, but could use a 2nd opinion.
Old 07-11-2003, 04:37 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
If there is not any other problem beside the code saying it's too lean then it should be the O2 sensor. It probably has too much carbon deposit covering the sensor that causes it to give a false reading.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 07-11-2003, 06:38 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
most likely the O2 sensor not getting a good reading, and sending back to the ecu to run your a/f ratio leaned out.
replace it then reset the ecu to see if it goes away.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-12-2003, 11:12 AM
robmcd16's Avatar
I replaced the o2 this morning and still having the same problem. Anyone have a suggestion? I reset the ECU and the CEL has not come back on yet. Anyone have any suggestions? I'm stumped.
Old 07-12-2003, 11:16 AM
robmcd16's Avatar
A little more info might help. If I start the car it idles fine, even if I give it a lot of gas. Once I put some strain on the engine by putting in gear and letting out clutch (even if I move a few inches) it will stall once I push in the clutch. After it stalls and I start it with the key it will run fine until strain is put back on it. If I start it by popping the clutch on the roll it will want to stall out again.
