Old 07-10-2003, 09:51 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Trunk won't stay open.
As I was installing the stereo in the sedan today, The trunk lid kept falling on my head until I rigged up a latch using a coat-hanger.
The torsion rods that keep it open are secure, and I can't figure out why there isn't enough tension to keep it open. Anyone else had this problem and was able to fix it? I'd be curious to know how.
Old 07-10-2003, 09:52 PM
ci5ic's Avatar
Re: Trunk won't stay open.
Actually, now that I think about it, that coat-hanger served multiple purposes today... I used it to slim-jim the lock because I locked my only key inside, I used it to run the amp wiring through the gromets in the engine bay, and I used it to support the trunk lid LOL.
Old 07-10-2003, 09:55 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
Hey man I have the same problem, My bar in the back that holds the trunk open had been warped by the speakers in the back deck, they were forced back there by some dumbass and now my trunk won't stay open, I hope someone has a solution.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 07-10-2003, 09:58 PM
ci5ic's Avatar
Hmmm... that sucks.
The bars in mine don't seem to be warped in any way, and as far as I can tell, they are secured properly, so I don't know what the problem could be. In the mean-time, I'm going to attach a spring to the post that sticks out of the "arm" and to somewhere else so that it will hold the trunk open, but will stretch when the trunk closes, but I'd like to know a permanent solution to the problem.
Old 07-10-2003, 10:01 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Sometimes the Shocks just get worn out. Thats what it sounds like to me
Old 07-10-2003, 10:22 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Replace the shocks.
That should solve the problem.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 07-10-2003, 10:28 PM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
You know Ive had this problem with mine since I got it way back when. I really want to know if there is a solution since I dont like having it not stay open. When I looked, I didnt see any shocks that would hold it open, but of course I didnt look extensively. I'll go look and if I can see anyhting, I'll let you guys know. Maybe I'll ask the guys at my work tomorrow.
Old 07-10-2003, 10:31 PM
If yours is a sedan it doesn't have shocks, only the hatch's do!
Old 07-10-2003, 10:39 PM
ci5ic's Avatar
Here's what I did as a band-aid fix:
I did this on both sides using a small bunjee cord. One side is attached to the little post that sticks out from the curve in the hinge, and the other is attached to some kind of plastic clip up in the corner of the trunk. If you pull back the carpeting, you can see a little plastic thingy attatched to the top of the inside of the trunk side, and the bunjee clipped in there nicely.
Old 07-10-2003, 10:46 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
If anyone is interested, I will find the link that gives you a parts list and instructions to just get rid of those bars and use the gas struts, like the hatchbacks use. It is really simple, it was originally made to be for the 7th gen civics because those bars are in the way of any aftermarket speakers, but it could be easily done on the 4th gen civics.
Old 07-10-2003, 11:37 PM
ci5ic's Avatar
Yeah, either that, or it would be cool to throw some linear actuators and a trunk pop on there and have it open by itself.
Old 07-10-2003, 11:44 PM
I will get the link from my friend who did it to his car. He used struts rated 10lbs higher than they recommended, so it kinda lifts itself about halfway up before you have to do anything.
Old 07-10-2003, 11:46 PM
ci5ic's Avatar
Sweet. I'd really be interested in that.
Old 07-11-2003, 12:54 AM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
i've thought about putting an extra twist into the torsion bars to make the trunk pop all the way open when i pull the latch... dunno if it would work... but just an idea...
Old 07-11-2003, 01:01 AM
ci5ic's Avatar
Good idea, but that'd be a pain in the ass to do.
