Old 07-10-2003, 06:42 PM
claystbird claystbird is offline
using rubbing or cutting compounds...
Hi all..Can someone answer this for me..If Im going to put a clear coat over my paint, and I plan to use a rubbing compound of some kind, like the 3M stuff, should I use it after I apply the clear coat, or before, or do I use it on the paint and then again on the clear coat..I know that sounds confusing..lol..Thanks..Matt
Old 07-10-2003, 06:48 PM
lowcrome's Avatar
lowcrome lowcrome is offline
Send a message via AIM to lowcrome Send a message via Yahoo to lowcrome
WELCOME TO AF! its a great place
can we have sum pics of your work?
u use the compound b4 the clear coat
but idk bout after
Old 07-10-2003, 07:37 PM
bah humbug's Avatar
This is getting annoying!
Maybe we should take away the FAQ from people who ask stuff like this!
I'm sorry for being harsh, but it's happening a lot.
Yeah and I know your a newb so I guess this once is ok.
Old 07-10-2003, 07:47 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
but idk bout after
No. Go ahead and clearcoat before polishing. The two paints will partially merge, and then you polish the cured clearcoat and it will even out.
Old 07-10-2003, 08:40 PM
themodelkid's Avatar
themodelkid themodelkid is offline
Send a message via AIM to themodelkid
Yeah, idk why you would polish befor clearcote????? Unless your high off paint fumes, you polish after clear cote, if you do before it can mess up ur paint.
themodelkid-Frank
2004 Dodge Intrepid SXT 3.5L HO
Brilliant Black Crystal Prl. Metallic
250hp, 250 lb ft tq.
1995 Dodge Intrepid 3.5L
Stone White
230 hp, 246 lb ft tq.
Supercharger in Works...
1987 Chevy S-10
Midnight Blue Prl. Metallic
300hp, 314 lb ft tq.
5.0L Baby...
Old 07-10-2003, 10:45 PM
lowcrome's Avatar
o i guess i better put the paint away
i didnt mean polish b4 the clear
just the rubbing compound b4 it to get rid of sum orange peel
then rubbing compound and then polish after clear
is that not a way to do it?
am i really high on paint fumes?
Old 07-10-2003, 10:56 PM
You aren't making sense.
Old 07-10-2003, 11:58 PM
lowcrome's Avatar
im prolly not makin sense
im tired
and hell u guys r the pros at this
u tell him how to do it
my models suck
forget i even posted in this thread
i cant help any1 i cant even help myself
Old 07-11-2003, 12:55 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
I get what you are saying, you need to remove orange peel from the color coats before you clear coat. Use micromesh polishing cloths, the 4000 grit should work well or you might even start at 6000 then clear coat, then use your polish and it will shine like a mother
Old 07-11-2003, 01:09 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
I'd be wary of using any wet chemical product between colour and clear coats... the clear may not bond or may react with the colour coat after it has been exposed to these chemicals. As dag65 said, use a high grit sandpaper between colour and clear, if you have fairly noticable orange peel. Be careful not to sand right through the colour coat, though. Good luck!
I work slowly!
Old 07-11-2003, 01:16 PM
dag65's Avatar
The only product that I know of that you can polish with and paint over are the plastic polishes
Old 07-11-2003, 01:42 PM
zerrocool's Avatar
zerrocool zerrocool is offline
if you give it a nice tamiya comound and tamiya wax you don't nead any clear coat, wath p-man's models he never uses clear coat and his painting is really good
Jan Paul
ok ok i can live with the new AF
Click here to see pictures of my R34
A.F.C AJAX
Old 07-11-2003, 01:44 PM
dag65's Avatar
True however if you are using a base coat clear coat system you need to use clear and even some pearls and mettalics are better if protected by clear
