Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 07-10-2003, 03:48 PM
Kebo Kebo is offline
Premium Stereo wiring color codes
Hey folks. I am trying to install a Clarion powered sub in my 2000 model extended cab F-150 truck and need the color codes for the wiring at the rear of the head unit. This is the Premium sound system which has two connectors at the rear of the unit. I don't have the service manual so I am hoping someone here does and is willing to look it up for me. Basically, I just need to know which wires are the left rear and right rear (both the + plus and - minus or ground) as well as the "remote device power on wire". Also need to know which connector(s) they are wired into. I would really appreciate it very much. Thanks! Keith
Old 08-12-2003, 04:36 AM
techpaul techpaul is offline
Info enclosed, if not too late.
According to a diagram i have you should find 4 connectors on the rear of the head unit (8, 16, 20, 20 pin). On the 16 pin connections are:
5 = Right rear +
6 = Right rear -
12 = Left rear +
13 = Left rear -
On one of the 20 pin connectors the power antenna is pin 2.
However, there is also, on the 8 pin connector:
1 = Subwoofer Audio -
2 = Subwoofer Audio +
3 = Subwoofer Audio Drain
4 = SW Enable/Clip Detect
Hope this helps.
Old 10-07-2003, 01:58 AM
VRSenator VRSenator is offline
why dont you just run two av cables to your amp and run the remote wire to the amp that would save all the stuffing around
LiVe HaRd DiE sIdEwAyS
