Old 07-10-2003, 03:24 PM
dredinyonkers dredinyonkers is offline
Unhappy motor question..
i have a 93 cx..which acura motor will drop in the easiest?
or what motor should i shoot for.. i really want a dual cam motor
but people let me know what you think...thanks
the ghetto's been good to me..
Old 07-10-2003, 03:26 PM
b18c dx b18c dx is offline
Send a message via AIM to b18c dx
h22 if you know someone who knows what they are doing, if not a b16 or b18. either the b16 or the 18 use your factory mounts, you'll need a mount kit for the h22.
my penis is 12"s. that would make it a foot. does that mean i have to wear a sock on it???
Old 07-10-2003, 04:04 PM
what car does the b18 come out of?
and which of the 2 is cheeper..
also which is stronger..
also if my penis was 12 inches i would never wear any clothes....lol
Old 07-10-2003, 05:20 PM
9teg1 9teg1 is offline
I have a gsr motor complete swap except ecu 2000 if u want it i live in upstate ny let me know email me at [email protected]
Old 07-12-2003, 01:49 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Go for the gsr. I'd still replace the mounts for the urethane ones. Gsr is a bit more but its also more power.
Old 07-12-2003, 08:10 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
depends on your cash flow
if money isn't an issue the h22 is your best bet. it has the most hp and torque for a honda engine (except spoon). the engine, tranny, and ecu should run you about 2500.
-1994 Civic coupe DX
Old 07-13-2003, 12:34 AM
integragsr98 integragsr98 is offline
The b18b comes out from 94+ integra LS/GS/RS, and the b18c1 comes out from integra gsr, and the b18c5 comes out from the integra type r, both the gsr and type r are vtec. the gsr engine would run anywhere around 2000-3500 if you don't know anyone to get it cheaper. The type r are extremely expensive engine, would probably run you about 4gees. IMO the type r are definitely stronger than other b-series engines.
check out this chart for the comparison on the engines.
http://www.4thgenerationcivic.com/engines/engines1.htm
It also depends on what exactly you gonna do with it, for example, if you want to turbocharge your ride with the stock internals of the engine, i would definately say go with the ls engine and tranny, though it has no vtec, but it handles more boosts safely (12-14 psi). But if you plan to fully build the engine for some serious power, go for the gsr or type r.
Make sure you get the right tranny also, pick the one that suits you better since they all have different gear ratio, like the ls has longer gear ratio and type r are shorter.
hopes that help. just my opinions.
Old 07-13-2003, 03:20 AM
greatandmighty1 greatandmighty1 is offline
this should answer major fundamental questions..
http://www.automotiveforums.com/vbul...861#post189840
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
