Old 07-10-2003, 01:45 AM
tino tino is offline
how do i make a fast eclipse with $5,000
I want to have the fastest car in my town. The fastest right now is a guy who has 2 rt/10 vipers 94 and 95 i think. I lookied it up and the 1/4 mile time is 12.5 seconds. I have $5000 to spend on engine mods for my 97 gst. Do you think i can beat him while still havin a reliable car?
turbos rule!!!
Old 07-10-2003, 01:48 AM
blasian_man's Avatar
blasian_man blasian_man is offline
i don't know about 12.5 sec on a front driver and still being streetable but here's a guide
http://www.dsmtuners.com/tuning-guide/2gturbo/
Old 07-10-2003, 01:51 AM
Ive seen an eclipse do it in 10 seconds on fast and the furious haha lol jk. But 4real ive seen mid 11s from a gst on the street.
turbos rule!!!
Old 07-10-2003, 01:53 AM
harrybeaver harrybeaver is offline
Banned
Buy twin turbos, a shit load of nos and a good ignition system.
the site that i posted a link to says:
"A Stage 2 setup will raise power output on a 2G car from 210hp to nearly 400hp. That can equal mid 12's or possibly high 11 second 1/4 mile times on the track depending on how well the car is tuned and driver skill level."
and no doubt its possible, but be careful
Old 07-10-2003, 01:54 AM
All i need is nos. il just press the botton as many times as i can from start 2 finish.
turbos rule!!!
Old 07-10-2003, 01:55 AM
and that kit was only $5000 wasnt it?
turbos rule!!!
Old 07-10-2003, 01:56 AM
Banned
Right On!
You become the boss when you go for the nos.
Beetles Kick Ass!
Old 07-10-2003, 01:57 AM
it says 5G's for the parts, not including labor, but you can probably find deals on some of the parts
ya to bad my engine would blow up if i did that. But if it wold work i could beat any1
turbos rule!!!
Old 07-10-2003, 01:59 AM
Ya, has any1 ever ordered any parts off ebay? And o ya u might wana watch out for that nos trick in the 3rd fast and furious
turbos rule!!!
Old 07-10-2003, 03:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
I put 1800 into my 95 and ran 12.7 at 109 (used 14b), but thats AWD. You'll want slicks or a 20g. You'll also need fuel mods including 190/660s and AFC/logger or DSMlink (prefered). Intake, exhaust, clutch, fmic, etc. Assuming you do all the work there should be enough money. 12s on race gas will be easy with 5k, on pump it will require some good driving but its certainly possible.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-10-2003, 03:49 PM
I dont c how gsx's are faster in the 1/4. I know they got the awd for not spinin out for quicker starts but once the gst grips it can use 100% of its power at one wheel? Not to be disin gsx owners or anything i just dont understand that?
turbos rule!!!
Old 07-10-2003, 05:58 PM
AF - Advisor
Let me attempt to explain. The ET in the quarter mile is all about the first two gears. That is, the launch and the 1-2 shift. ET is very dependant on those two things. The mph is all about the top end of the track. Let me try to illustrate these points before we get into the AWD vs FWD debate.
I'll use examples that I have personally expereinced with my car, but this happens for everyone, and its been well documented, well known, and the reason behind it are known. That being said...
If you screw up the first part of the run ET goes to hell, but mph is largly unnafected. Example. My clutch wasnt holding so I had to baby the launch and the 1-2 shift. ET was in the 15s, but mph was 119, which is good for mid 11s. The 60 foot time was a 2.8 or so. I could give multiple other examples of this.
If you bollix the last half of the run, mph will suffer, but ET wont change a whole lot. Example. I broke on the 3-4 shift when I was running consistent 12.7s. MPH was hurt, only 80 instead of 108 or so. But ET was still 12.8. I could give many examples of this too...
So now that we have established that, lets talk about AWD vs FWD.
AWD is all about getting the job done off the line. Look at your typical front driver, and this goes for any of them, not just DSMs. On street tires you are lucky to break 2.3s... On my car with street tires I run 1.5s to 1.6s, with the average Joe still getting at least 1.8s on a normal run. Now consider that ET is largely dependant on the launch and the 1-2 gear. Its widely known and accepted that for every tenth you take off your sixty foot, you can take two to three tenths off the ET. So in the extreme case of my 1.5 vs a FWDs 2.3, thats 1.6 seconds to be gained just because it launches harder! So you see, you're simply underestimating the advantage the AWD car has for ET. And you can see this at the track every night. I absolutely destroy everything off the line. Even a mid 9 second Monte with massive slicks and RWD I ran that pulled his front wheels up for 50 feet ran a 1.66 to my 1.56. So FWD doesnt have a chance... For AWD vs FWD I have some baddass videos of my runs that illsutrate it, but the site that was hosting them tossed em.
Now for mph, the FWD tends to do just a bit better. Why? The front half of the track doesnt matter and the lower weight allows a slightly higher mph. But mph doesnt win races, ET does
Hope this clarifies things a bit.
Kevin Jewer
Old 07-10-2003, 06:09 PM
Ya that helps out alot. So u can beat all fwd cars off the line but they have a better mph on the run. Which means on the stip an awd car would b better but like racin some1 on a hghway or a long street run, right???? Also if u rev it up all the way and dump the clutch will u spin out at all?
turbos rule!!!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
