Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-09-2003, 04:43 PM
nick325i nick325i is offline
Post overheating
My fairly lightly modified 1995 325i over heats in traffic or any slow or stopped situation. I put a Active Autowerke's 72 degree thermostat, and it did nothing. i have not clutch fan anymore, but thats been gone for a few years now. i'm not sure if my electric fan is broken or just not up to the task. is there a different fan switch, or anything i can do to make it stop.
Old 07-10-2003, 07:23 AM
buymeabmwm3 buymeabmwm3 is offline
I read a tech article a while ago that gave instructions for how to install a manual switch to turn the radiator fan on and off. Hmmmm, wish I could remember where it was. I seem to recall it involving wiring a switch to the two wires at the top left of the radiator. Hope this info helps for a google search or something. Anyone else heard of this?
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 07-10-2003, 05:01 PM
ti fan switch?
I've heard something about putting a 318ti fan switch will make your fan come on sooner. If anyone know about this then I wanna know.
Old 07-10-2003, 08:46 PM
Celsdogg's Avatar
Celsdogg Celsdogg is offline
i read the same thing somewhere, but i swear it was foir the E30, not sure if it would be the same for the e36. . .
Current:
1990 BMW E30 325i
2004 Subaru Legacy
2008 Toyota Sienna LE
Retired:
1978 Cadillac Fleetwood Brougham
1990 Volkswagen Jetta GL
1991 BMW E30 325i
2001 Honda Odyssey EX
Old 07-14-2003, 05:48 AM
BMWTECH BMWTECH is offline
Hey, your problem is probably the water pump. Unfortunately the water pumps have a plastic impeller and over time they break off. If your vehicle is overheating in a normal amout of time than that is more than likely your problem.
Ok, just reread your question, sorry. The overheating in traffic is most likely your electric fan. The clutch fan is there for normal use and if you remove that the cooling system isn't as efficient. The aux fan comes on with ac or an extreme heat situation. The power to the fan is switched on by the fan relay which is located in the front power distribution box located in the left rear corner of the hood, as if you are sitting in the driver seat. It can be modified there. If you want, pm me and I will let you know exactly where to splice in. I need to look at the ETM to find out the best point.
Old 07-16-2003, 08:29 PM
Reread because of the edit, sorry if I mis lead you. Didn't read the question thoroughly.
Old 07-17-2003, 11:10 AM
Celsdogg's Avatar
tech:
does the E30 also have a plastic impeller for the water pump?
once upon a time my E30 was overheating and come to find out that it was the thermostat, my ladies dad replaced it and it then ran cooler then it did before it started to overheat. . .
Current:
1990 BMW E30 325i
2004 Subaru Legacy
Retired:
1991 BMW E30 325i
Old 07-17-2003, 01:45 PM
No, the E30 water pump has a metal impeller. They started the plastic impellers with the e36. They did go away with the plastic to metal and now back to plastic.
Old 07-18-2003, 09:15 AM
Celsdogg's Avatar
so does the m54 have a plastic or a metal impellar?
Current:
1990 BMW E30 325i
2004 Subaru Legacy
Retired:
1991 BMW E30 325i
Old 07-18-2003, 10:59 AM
The M54's have a redesigned plastic impeller. I have yet to see a prob with them though.
Old 07-18-2003, 11:36 AM
Thanks for all the info Tech!
1992 BMW 325i conv.
FOR SALE!!
