tire size for new rims ?
i just wanted to know the tire size for my honda. the format is something like xxx/xx/xx i think. i have no clue how u tell this number... im getting 17 inch rims if that helps , thanks in advance
Which Honda would help.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
Go to Tirerack.com & you will find out! add 17's & then see what tire size it says
Example tire size P345/35ZR18 P- passenger car tire 345- Nominal section width in millimeters 35- Nominal aspect ratio (section height-to-width ratio) Z- speed rating(Z rating-180mph) R - radial tire 18 - Nominal rim diameter(inches) |
17's on a 98 accord. Your tire size is probably gonna be somethin like 215/45/ZR17 depending on what type of tire you are looking for. Usually, when you buy rims, the tire size will be predetermined by whoever is selling them. Each seller has different tire packages as far as what brands they deal with.
If you are buying rims and tires separate, then you need to find out how wide your rims are (probably 7in or maybe 7.5) to see what width tire will mount properly. 205, 215, or 225 depending Choose your tires carefully, they're the only thing keeping you on the road!
ECNATSISER AL AVIV
