Old 07-09-2003, 12:05 PM
Pontz81 Pontz81 is offline
Question camber adjustment
I just installed H&R sport springs into my 2000 civic si. The estimated drop is 1.5-1.75 inches all around. I was told that under a 2 inch drop, no camber kit is required. When I eyeball the camber, it looks to be signifigantly offcenter. I know that Honda's have no adjustment for camber, so my question is: can the camber be corrected without a kit, or should i install one before i take the car to be aligned.
Old 07-09-2003, 12:28 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
You don't need a camber kit, just use some washers, I mean, thats basically what a camber kit is anyway. Also, did they shave the bump stops at all when you got lowered?
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 07-09-2003, 12:52 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
with that little of a drop i don't think you need a camber kit. your camber is off, but not enough to wear out your tires. an alignment shop should be able to reduce most of your offset. i bought a camber kit, but im lowered 3"....
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
