Old 07-09-2003, 11:23 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Straight Pipes?
So, I may be getting a CRX for pretty cheap, and if I do, it's going to be all race. I won't have to worry about passing emissions with it, since it won't be street-driven anyways, just trailered to and from the track. So, I was thinking about running straight pipes, no cat, no muffler...
Would this significantly improver performance, or would there be a loss of performance due to less back-pressure?
Old 07-09-2003, 11:32 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
i dunno, but i know one thing it is gunna be FUCKIN LOUD!!!!
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 07-09-2003, 11:34 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...run it out the side of the front bumper in front of the wheel
SOLD!
Old 07-09-2003, 11:35 AM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
shoudl be just fine. there are like half a dozen race-only hatches / crxs in my area that just run a header basically... it is loud as fuck, but there's nothing wrong with it.
Old 07-09-2003, 11:41 AM
chopstick1981 chopstick1981 is offline
back pressure has no positive effect at all on performance, what will make a difference though is the vacuum, since exhaust timing overlaps tdc on the exhaust stroke it relies on the momentum from already traveling exhaust to create a vacuum effect and further clear exhaust from the cylinder through the first part of the intake stroke. I read this all in an arcticle somewhere, but i cant seem to find where it is anymore.... i do remember it saying though that backpressure has absolutely no positive effects on engine performance
Old 07-09-2003, 12:48 PM
ci5ic's Avatar
Thanks for the info.
I'm thinking if I do straight pipes, I will have them exit the side of the car, just in front of the rear wheels, kinda like the way Worshp has his set up.
Old 07-09-2003, 12:59 PM
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
that would be awesome if you would make flames come out the pipes.
Name is Adam
Old 07-09-2003, 01:34 PM
marked001's Avatar
Moderadur
yeah!! just like in fast and the furious!!!
SOLD!
Old 07-09-2003, 02:21 PM
EFStali's Avatar
except these flames will actually be real and not computer generated
Name is Adam
Old 07-09-2003, 02:35 PM
marked001's Avatar
Moderadur
...those are real... didnt you see any of the production pics where they had the trunks of the cars filled with propane? haha... seriously.
SOLD!
Old 07-09-2003, 02:37 PM
EFStali's Avatar
oh ok, then uh i guess ill shut up on that subject. actually come to think of it my grandpa did that to his 67 chevy, where he had the exhaust coming out the side, and then put spark plugs in the pipes, that were connected to a battery and and then to a on off switch...it was pretty nice
Name is Adam
Old 07-09-2003, 02:39 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
what motor are you going to be using? if its a D i think you can make the bisimoto race header exit the side of the car like your talking about
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-09-2003, 04:11 PM
darolh darolh is offline
If it's a track car and there are no noise restrictions at the tracks you go to (better check) go for open pipes.
Some organizations, tracks or classes require that you are below a certain noise level. This often (not always) means a muffler.
Old 07-09-2003, 06:51 PM
kapt kapt is offline
Send a message via AIM to kapt
my friend has a straight pipe on his 3k gt plus dual mufflers and it adds lots of power. doin the same to my hatch soon ;]
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
Old 07-09-2003, 10:06 PM
hilltopper hilltopper is offline
oh yeah there super loud, heheh had my exauset pipe break off at the flange that connects to the cat, damm it was loud, but nothing a weilder couldnt fix
