Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-09-2003, 10:20 AM
integra_Ls17 integra_Ls17 is offline
I'm doing up my integra Ls, any suggestions?
I'm doing up my honda integra Ls 1990, i have $5000 to play with, does anyone have any suggestions as to what i should do first?
Old 07-09-2003, 10:33 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Wrong forum! Moved...
Old 07-09-2003, 05:45 PM
hotwheelzcivic69 hotwheelzcivic69 is offline
Send a message via AIM to hotwheelzcivic69
Suggestions
I'm doing the same, this is what i'm going to do. A friend ran the same setup as I"m going to and ran a 13. on 5psi of boost......plus he was a crappy driver. So if you build it right and run more boost you should be pretty quick.
GSR-tranny
ACT Clutch
9lb. flywheel
Knife-edged crank
eagle h-beam rods
ross racing pistons 9:1 Compression
blockguard
new crower valvetrain
crower turbo cams
jg victor x-manifold
jg throttle body
t3/t4 turbo set-up
driveshaft shop axles
msd 6al igntion
Old 07-09-2003, 10:34 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
sounds good only thing i would add is darton sleeves you can run alot of freakin boost with them suckers
Old 07-10-2003, 03:34 PM
redmanjd redmanjd is offline
go high compression. i am running 14.3 now and i have a turbo in the back of the car. My freind has an ls (stock) with a t3 pushing 10psi and runs 13.2 stock he was running 15.3. So if i boost 7psi i should hit high 12's
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
