Old 07-09-2003, 08:35 AM
Mr. Death Mr. Death is offline
sohc zc vs. D16a6
Is there a difference between the 2 engines? I heard someone say on this message board that they were the same and then I've heard of people swapping from 1.6 to a zc. If there the same then why swap?
Old 07-09-2003, 08:48 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..its all a big mystery.
SOLD!
Old 07-09-2003, 08:54 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
i dont see the point and i dont think ive ever heard of any going z6 to sohc zc, theres people that have gone from d15b2 to sohc zc............
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 07-09-2003, 09:51 AM
marked001's Avatar
Moderadur
here's some info on the sohc zc....
SOHC PGM-Fi
16V SOHC, Programmed Fuel Injection.
Max Power : 120ps.
EF-series Honda Civic 36i (4door).
DA-series Honda Integra RXi and ZXi.
DB/DC-series Honda Integra ZXi.
Revised DB/DC-series Honda Integra, various models, eg Ti, Xi-G, Xi(4WD).
SOLD!
Old 07-09-2003, 10:45 AM
chopstick1981 chopstick1981 is offline
I've heard the difference is about 12 hp. maybe just a wilder cam, or more compression. But visually the two look identical except for the "zc" stamped on the engine code
Old 07-09-2003, 10:56 AM
I have one and I'm wondering if it's worth putting money into the swap. Right now I have the shitty d1.5 and am looking for something a little more quicker. I think I might have to rebuild the thing cause it's sitting around with the head taken off and it preety dirty. Money .money, money!!!!
Old 07-09-2003, 11:00 AM
marked001's Avatar
Moderadur
if you're swappin out a d15 and you already have the engine..then why not...its a simple simple swap aside from the mpfi conversion... go for it since you've already got the engine...
SOLD!
Old 07-09-2003, 11:19 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
if you already have the engine then do it to it. if you don't have the engine...you could always just do the MPFI conversion. the 1.5 being DPFI is a big reason it lags so bad. get some more fuel flow and you'll get more response
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-09-2003, 01:46 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
okay as far as i can tell from all the research ive done and the various people ive talked to... going to a sohc zc isnt that great if you have a readily available dohc zc because the diffrence in the two is about 10-15 hp so you might as well go with the dohc zc.
but if you happen to already have a sock zc then the diffrence can be alot depending on what your coming from. any dpfi system isnt going to take full advantage of the engine so your looking around 105-110 hp which is about the same as the Si. but if you happen to have an Si or mpfi already then you can expect more like 115-120hp. and im talking mostly stock with no I/H/E or maybe one of the three.
In the name of science at the end of summer im gonna see if i can get some money together to get my sohc zc dyno'd since im running a completely stock set up. when i get this done i will post my results. after i get it dyno'd i should have my mpfi ready to go and ill go back to get it dyno'd to see the new numbers and post results.
either way the sohc zc is the same engine as the d16a6 but it has a higher compression ration (instead of 9.1:1 it has 9.6:1 if i remember correctly) and because of this it can pump out the extra bit of pony power. but thats all from me for now ...
as a side note if anyone has a sock zc engine pics can they drop me a line i have a few questions.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 10-24-2004, 04:38 PM
ericray ericray is offline
zc vs. the d16a6
I have a sohc cam zc in my crx si its better than the stock engine and Im glad that I did the swap. also I got the engine from nippon motors for 395.00 very cheap and finnished the swap in two half days
Old 10-24-2004, 04:45 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: sohc zc vs. D16a6
hey eric, I'm going to let you in on a secret...
THIS THREAD IS OVER A YEAR OLD!!
