View Poll Results: Is 84k miles too late to start runnning Synthetic Oil?
Yes 1 33.33%
No 2 66.67%
Voters: 3. You may not vote on this poll
Old 07-08-2003, 10:40 PM
nkoenig nkoenig is offline
Send a message via AIM to nkoenig
Synthetic Oil Question
I have a 91 eclipse 1.8L SOHC
Old 07-08-2003, 11:44 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Do a leak-down and compression tests, if they are good, give it a shot, and if you burn it, oh well.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 07-09-2003, 01:41 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Its never to late, that is an urban myth.
Old 07-09-2003, 04:45 PM
Talon007's Avatar
WTF are you talking about?? an urban myth my ass, go do some research on synthetic oil, because I'm not explaining it to you
Chris Clark
www.Talon007.com
Old 07-09-2003, 05:03 PM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
The whole thing started in the latter days of hot rodding (70's - 80's) Older cars built back then had fabric (main seals) and cork (VC gaskets)
When they got older and had tons of miles on them , addition of synthetic oil would cause the seals to leak , because it would clean out the grime build up and change the tolerance , creating a leak. Most newer cars built since 89 - 90 use neoprene seals , which also contains an internal spring. These type of seals rarely leak , unless exposed to uneven pressure , were installed improperly to begin with , or were exposed to extreme temperatures which would warp the seal housing.
I personally used synthetic oil in my 91 Beretta GT , which had 168K miles on it when I got it , and it never leaked a drop. I'd say if your SOHC 1.8 is in good shape , go for it.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 07-09-2003, 05:28 PM
zer0bot's Avatar
zer0bot zer0bot is offline
i switch to synthetic oil in my 95 civic at 100k and never had even the slightest hint of a leaking problem. RockinWRX is right there souldn't be a problem with leaking if it isn't already one
zer0
"It's like playing rock, paper, scissors and sucker punch to the throat. The sucker punch always wins."
Old 07-10-2003, 01:10 AM
blasian_man's Avatar
blasian_man blasian_man is offline
the easiest way for me to put would be that it lasts a lot longer, a whole lot longer than regular oil, since was originally made for jet engines
Old 07-10-2003, 04:05 PM
Just ignore them. Trolls can't stand to be ignored.
Old 07-10-2003, 09:14 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
if i were you i would go for it. the worst thing that is going to happen is your going to burn it. i would run compression checks just so you dont waste your money on synthetic if the car is burning oil. because synthetics can be slightly more expensive or about the same in the longrun. depending on manufacturer(of oil) and personal beliefs. i got my car at 82,000 the guy before me was running a synthetic blend. when i got it i switched to a fully synthetic(preference Amsoil) and it has never had a problem.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
