Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-08-2003, 09:17 PM
ROCKSTAR1892 ROCKSTAR1892 is offline
Question i need more help
im installing my new header this weekend on a 2000 acura. my problem is, i have no idea on the correct torque specs for my acura. so if any one know the correct amount , i would be thankfull. one last thing, any thoughts abouts short shift kits ( if they help, pros/cons, are they worth it, so on/so forth ) again any info given, i would be thankfull.
Old 07-08-2003, 09:30 PM
iNgLi$ iNgLi$ is offline
torque for a 2000 Acura Integra LS is 124 ft-lbs @ 5200 RPM.
Old 07-08-2003, 09:36 PM
o ya, a short shift kit will help. shifting is effortless with sum, its easier to reach all the gears, 5th doesnt seem so far away. But be ware sum short shift kits but the shifter way too low...
Old 07-08-2003, 11:07 PM
thanks for the info but in the amount to torque down the bolts on the header. if any one know, let me know. thanks
Old 07-09-2003, 11:30 AM
lol...
Doesn't it tell u what the torque spec is, the instructions?
Old 07-09-2003, 11:43 AM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
You're best bet would be to just call a shop. Or maybe tighten it a little after its "tight," about as good as you can do it. A machine would probably do damage if you're not careful.
Old 07-09-2003, 11:50 AM
moleodonuts's Avatar
moleodonuts moleodonuts is offline
Send a message via AIM to moleodonuts
Watch it on the short shifts... as you prolly know, some of them are just a shorter stick and don't really reduce the throw... if you're going to do it, put the money in; get a good one.
95 Civic Si - Thunder Grey Exterior
-Performance: B16A, JR supercharger @ 9 psi, JR FPR, Tokico 5-wy Adjustable Shocks, Eibach springs, F/R strut and swap bars
-Audio: Alpine 9815, 3-way component Pheonix Gold speakers
Old 07-09-2003, 08:48 PM
the best line ever from a movie ( trainspotting ) and the instruction dont tell me sh*t so if any on knows the amount of torque the bolts need, let me know. thanks
Old 07-09-2003, 08:54 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
You want a straight answer? Torque that b*tch so that it won't rattle off. You want the right answer? Get a Helms manual. Common sense should guide the wrench if you don't have the manual.
Old 07-09-2003, 09:17 PM
94blklighting 94blklighting is offline
dont torque the hell out of the headers. i did that to one of mine and didnt notice and it just keep turning and turning and you get the idea. tap and die here i come. could thing i caught and didnt have to tap it to much and the orginal bolt fit right into the hole.
Old 07-09-2003, 09:20 PM
Sid77 Sid77 is offline
Ok use what b16 said but also listen to blklighting "Torque that b*tch so that it won't rattle off" but remeber "dont torque the hell out of the header or tap and die here i come"
Old 07-10-2003, 08:02 PM
thanks alot guys, ill take both pieces of advice.
Old 07-10-2003, 11:29 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
c'mon guys here is the answer head bolts for the manifold/header 23lbft the bolts on the converter 16lbft
Old 07-11-2003, 04:10 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
damn u...u always take the ones i want...
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 07-11-2003, 10:34 AM
I just torque mine to 250 b.c its max spec on my torque wrench. That's good right?
