Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 07-08-2003, 04:04 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
How do I swap the front grill on a 2000
Is it held on by screws or what? I haven't tried yet but I'd rather go into battle prepared.
Old 07-08-2003, 05:58 PM
94civic's Avatar
94civic 94civic is offline
its probably held in by screws(phillips) or those little plastic clips
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 07-08-2003, 10:57 PM
x007den x007den is offline
Send a message via AIM to x007den
Its help in by the type of screw where you just need a phillips to lift the tabs up and out they come, there's around 10 of them.
Old 07-10-2003, 11:52 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
Be careful with those clips. I have busted a couple off before...
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 07-11-2003, 12:06 AM
Ricochet's Avatar
Banned
cool thanks for the advice guys.
