Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 07-08-2003, 02:32 PM
johndezman johndezman is offline
radio wiring help
i have the factory "premium" radio out of my old lebaron gts that i want to install in my boat.
its the "premium" radio with the joy stick balance, 5 band equalizer and cassette deck.
on the rear of the chassis, above each wire of the connectors each conductor is identified.
my 1st question regards the fourth wire of the grey connector. its labeled "park". how should this be connected (to what) - or do i need to?
also on the grey connector would be two power leads, regular main power and presumably the memory maintain as well as instrument lighting.
question 2 - can the two power leads be spliced together ( i know if i disconnect the battery i'd lose my presets) my questioon is more like is there enough "amp acity" to power the unit wired this way?
Old 11-01-2003, 04:56 PM
86shelby_charger's Avatar
86shelby_charger 86shelby_charger is offline
Send a message via MSN to 86shelby_charger
go to any car audio shop and get the harness that pulgs in the back of the radio.. metra is a good brand and the model# is 71-1870and will plug right into the stock deck.The package has all the color codes for the wiring. Make sure it's 71-1870, and not 70-1870, 70-1870 hooks up to the harness in chrysler cars!
