Old 07-08-2003, 02:56 AM
TurboNutzz's Avatar
TurboNutzz TurboNutzz is offline
Changing timing belt...
I need help on this. If any one could give me a good site or good description of what to do exactly it would be very helpful. I already bought the chiltons manual and its kind of vague on some steps. i already took off the top cover and the power steering belt. i'm not sure in what to do now. I know i need to take off the crankshaft pulley but im not to sure about when i'm supposed to set it at TDC.
Do I do it before or after i take off the belts? I know this is a really important step so if you guys could help i'd really appreciate it.....thanks alot...
Old 07-08-2003, 02:25 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
check out www.tech.hybridgarage.com
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-08-2003, 05:22 PM
TurboNutzz's Avatar
I can't get the link to work. are you sure its spelt right? thanks again
Old 07-08-2003, 06:20 PM
crxlvr's Avatar
my bad here is the link http://tech.hybridgarage.com/index.html
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-08-2003, 07:56 PM
civ69's Avatar
civ69 civ69 is offline
Send a message via AIM to civ69
I just did mine on my civic, and the only thing that really gave me a problem was the crank pulley bolt, its torqued to 135 ft lbs. Most impact wrenches wont be able to take that off, I had to fab up a crank pulley holder and beat on a breaker bar with a sledge to get the bolt loose. Basically to replace the timing belt, you take off the valve cover, top timing belt cover(then set no1 cylinder to tdc, there are marks on the cam pulley), a/c belt, ps belt, and alternator belt. Unbolt the two top engine mount bolts and take off the lower timing belt cover. Now loosen the timing belt adjuster bolt(dont take it off, just loosen), now you should be able to get the belt off. Installation is the reverse order, you might want to replace the water pump while you have everything apart.
Old 07-08-2003, 08:00 PM
Tercel GTS Tercel GTS is offline
Send a message via Yahoo to Tercel GTS
in the future, bump the key with breaker bar being held by frame, the starter spins the motor in the direction needed to loosen the bolt....
ps, that's almost ANY car
click to chat at StonerScript
Old 07-15-2003, 03:44 AM
TurboNutzz's Avatar
thanks guys i couldn't take it no more and i put the belts on drove it to a servicse station right down the road, had them hit it with their 3/4 impact and then lightly tighten it so i could drive homw and finish the rest. im pretty mush done with everything, except there is a slight knocking or radilily when i let teh car idle for a while. im not sure it might be that i need to tighten shuff some more. buts thanks for the infoss.......
Old 07-31-2003, 01:12 AM
93DC2 93DC2 is offline
DON'T MISALIGN THE TEETH ON THE BELT!!! you'll throw off your timing then you'll regret it. i know what you mean about the crank pulley nut. that was a BISH!!! yeah do your h2o pump too while u at it. i upgraded to spoon gears too since i had everything off. left my a/c belt off too, even tho it's hot as hell here in Okinawa. i'm talkin humidity with a capital V! however you spell humidity...
