Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-08-2003, 02:21 AM
TurboNutzz's Avatar
TurboNutzz TurboNutzz is offline
A little advise on rims
Hey if anyone could give me some advise that would be great. I'm hella stuck on the 3 piece cr's by racing hart, but they only come in 18's and 19's. Plus my car is sitting about 1.7" lower. I'm pretty sure i could fit it but what about the turning and other sheee. The second thing is offsets, what would you guys recommend for any rims size? thanks for the help....
Old 07-08-2003, 02:40 AM
BullShifter's Avatar
35mm-45mm backspacing 40mm is about the average
With the 18's & some 215/35R18 tires you should be fine @ stock height. The tire is slighly larger less than a 1/2" so you should have no rubbing problems if you dont already.
17's is the largest I would go on that car, for performance stick with 14" or 15" rims
Tire Rack
Whalen Tire
can help with all your fitment issues
Old 07-08-2003, 02:46 AM
TurboNutzz's Avatar
Thanks for the info..
Old 07-17-2003, 05:31 AM
elitethug elitethug is offline
if it rubs, roll the fenders. i think tirerack.com has an equipment you can rent from them to do it yourself. you can also just go to any custom wheel shop and theyll do it for you
Old 07-17-2003, 05:44 AM
TurboNutzz's Avatar
thanks again for the info...but just to calrify you guys won't go with the 18.75's on a 1.7 drop???? cause damn the 3 piece cr's are NICE!!!
Old 07-24-2003, 08:48 PM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
Re: A little advise on rims
Whats up TN...
Like JA had said...17"s would be the best fo ryour car and also any other import/domestic of that size (compact) for over all look and daily drive. If you want to show...go with 18/19". I had 18" RH M7000's on my civic and it looked tight..but to drive...it was hell!
Couldn't give you any advice on "rolling your fenders"...sorry.
Stick with 17 or lower...and remember...if this is a daily driver...you've got to think smart! 17" will give you a good look but less headache. I've even seen guys with your same car and only 14,15,16" rims and it looked tight....lowered of course.
my
Old 08-04-2003, 06:04 PM
TurboNutzz's Avatar
true that....i'll probably go with the17 inch 3 piece m5's.....thanks fo tha advise...
Old 08-04-2003, 10:14 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
get some 17in 5Zigen wheels
Darrell
thegrumpysergeant.net
15" hundred spoke player rim caps i need blindside135 Cars/Parts for Sale/Exchange 1 03-31-2010 03:42 AM
Considering Upgrading to Bigger Rims Nav712 Town Car 5 03-25-2009 02:57 PM
Please Help me answer some questions with Rims Banana_Peter Mustang Talk 2 02-21-2009 10:55 PM
fitting different rims to old F-250 steve f. F Series 1 02-16-2009 10:44 PM
Little Advise Please . nativeer3 F Series 5 05-03-2008 02:51 PM
