Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-03-2026, 05:51 AM
gootchie gootchie is offline
Update to 2015 Explorer charging issue
I have an appointment to take it in to get the serpentine belt replaced, for it does have cracks in several places. Also recently, if using the radio with the engine off but the key in accessory position for more than 10min or so will significantly drain the battery to the point where it needs a jump. Never had this happen before. Did test battery and it checks out. Positive cable has some corrosion though. Will let shop test alternator. Still shows charge light for a minute or two when starting up cold, then fine rest of day. Other than the battery draining when radio is used with engine off, starts just fine.
Hoping the alternator isn't going, that's by far the most expensive thing to replace. Anything else I can do before replacing alternator?
Old 11-03-2026, 01:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Update to 2015 Explorer charging issue
Do you have auto headlights that maybe are also turning on for the duration when sitting in the car listening to the radio?
If so inclined, you could ask the shop if they could put their scan tool on the car when replacing the belt to monitor the performance of the charging system. A professional scan tool should be able to monitor the charging system output as well as show what it believes the battery health is.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
gootchie (11-04-2026)
Old 11-08-2026, 10:34 AM
Okay, replaced battery, serpentine belt, and positive battery terminal (fairly corroded). Same problem, charge light comes on for minute or two on cold startup then fine the rest of the day. Alternator checks out, haven't checked it when problem occurs yet. Issue fairly consistent. Any ideas?
Old 11-09-2026, 01:51 PM
shorod's Avatar
SHO No Mo
Have you had a chance to check the system voltage just prior to starting, while the starter is spinning the engine, and once the engine is started, both while the Charging indicator is on as well as once it's semi-warm?
Having those measurements are going to be pretty important to offer suggestions of much value.
-Rod
