Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-19-2026, 02:08 PM
gootchie gootchie is offline
2015 explorer charging issue on startup
I have a 2015 Explorer base model, 3.5 V6 (NOT ecoboost). Lately when I first start it up in the morning I've been getting a "check charging system" message with a charging warning light. This'll last a few minutes at idle, then it will go away and not return the rest of the day, as it seems the alternator finally catches up. Before that, if I try to start driving it'll lose power steering. Once semi warm I have no further problems. I can't hear any alternator noise, nor any other indicators of imminent alternator failure. I did clean a fair amount of corrosion off the positive battery terminal, then made sure both were tight. Battery is two years old, no issues so far but probably should get tested. Am I looking at an alternator replacement or rebuild, or might there be a simpler explanation? Mornings are getting colder so I need to figure this out soon.
Old 10-19-2026, 04:35 PM
maxwedge maxwedge is offline
A990 racer
Re: 2015 explorer charging issue on startup
Try and check the charging voltage at the battery when the problem occurs.
The Following User Says Thank You to maxwedge For This Useful Post:
shorod (10-20-2026)
Old 10-19-2026, 05:48 PM
aleekat aleekat is online now
What condition is your serpentine belt?
Post back, that's what makes Forums Work.
