Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-28-2026, 07:24 AM
LEM LEM is offline
2008 T4R Limited V8 AWD Rear ABS Sensor Wiring Harness
I'm a knit wit, one of the first things I noted in my own bearing replacement guide was to remove the ABS sensor BEFORE removing the axle shaft. Well, I skipped that step because I thought I could go by memory. Anyway, when I pulled the axle out, I broke the two small wires going to the ABS sensor. I was able to solder them but I'm concerned they may cause an issue. I'm having a hard time finding the right replacement wiring harness, I see some for the left hand side, rear, and some for center, but I've not come across one for the right hand (passenger) -side rear. I see some harnesses that seem to have one main connector and two lines, one going to one side and another to the other. So, any leads on what I need to get to replace the wiring for the right hand rear ABS sensor?
Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
Old 09-28-2026, 07:33 AM
maxwedge maxwedge is offline
A990 racer
Re: 2008 T4R Limited V8 AWD Rear ABS Sensor Wiring Harness
If you are worried about sensor continuity to the abs module, a good scanner can confirm wheel speed input, also if it bad, the abs lite would come on.
The Following User Says Thank You to maxwedge For This Useful Post:
LEM (09-28-2026)
Old 09-29-2026, 04:46 AM
LEM LEM is offline
So far so good; I reassembled the axle and brakes and there was no dash light indicating an issue with the ABS sensor...thank The Lord!
