Old 04-25-2026, 01:48 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
1967 McLaren M6A Sunoco
This is a Fisher Model & Pattern resin kit from the mid '90s. The castings are quite nice. It also has white metal & aluminum parts and a nice sheet of photo-etch. I really like the note at the top of the very informative instructions: "This kit is not suitable for children or adults with bad attitudes."
The parts are cast well but like many resin kits there are some pinholes to clean up in the body but they are not in difficult places to deal with and none are on the main surfaces.
I scribed the panel lines a bit deeper while I did the standard clean-up. Still a bit more work before it's ready to paint.
Now that all the parts have been dry-fitted, a base coat of white primer was applied to the body…
The Sunoco Blue is a mix of Testors Dark Blue and Dark Red.
Old 04-27-2026, 10:09 AM
Re: 1967 McLaren M6A Sunoco
Even though the tires are resin they look great on the finished models. The wheels have cast white metal outer rims and on the other Fisher kits I've built they polish up fine and look great.
I noticed one of the fronts had a small defect where the mold didn't fully fill that was too deep to polish out.
I soldered it up, filed it smooth and repolished it.
Old 04-29-2026, 05:34 PM
When I polished the rear rims I noticed they had some irregularities due to shrinkage during casting that also could not be sanded/polished out. I was so focused on the issue in the front wheel I missed that the other front also had similar shrinkage issues as the rears.
Machining the surface to smooth it out is an option, but with white metal being so soft it is risky to clamp in a chuck tight enough to hold it and not deform it. So I machined a new set from aluminum. The kit supplied parts are next to the tires. They probably would have looked OK, but I know it would have bothered me.
Old 04-29-2026, 08:47 PM
These are the assembled wheels with the aluminum outer rims.
Old 05-05-2026, 08:12 AM
This is the photo-etch sheet.
This is one piece of PE folded up origami style for the tub. It's engineered very well.
Old 05-05-2026, 08:14 AM
The seat belts were done with tape and the supplied PE hardware.
Old 05-05-2026, 07:43 PM
Last night, and after the Testors enamel cured for a while, I color sanded it and then shot the last color tint coat of TS-72 Clear Blue. It is not recommended and it can be very risky applying lacquer over enamels, but I have done this process with these paints enough to do it safely, and in 24 hours it’s even safe to handle. Now it has that “electric” quality the real car has.
Old 05-09-2026, 01:30 PM
The intake stacks were painted with FusionFirm Chrome and LP-65 Rubber Black. The hose clamps are decals.
Old 05-11-2026, 02:41 PM
The mirrors are white metal and would polish up nicely, but I wanted them pinned for a stronger attachment to the car and the pylons are very thin; the same thickness as the pins I used. So after cleaning up the pylons the mirrors were painted with Alsa Chrome and Mylar discs were added for the faces.
Old 05-13-2026, 10:41 AM
The dash is two very thin pieces of photo-etch. The gauges printed on the instructions were to be cut out and sandwiched between the two metal pieces. I made new gauge decals instead.
Old 05-16-2026, 10:35 AM
I was very relieved when the first decal went on with no problems. (The kit includes two sheets due to them being delicate; a nice touch.)
Old 05-23-2026, 11:49 AM
I took my time putting one or two decals on each evening. They were prone to silvering so I made sure each one was clean before adding another.
It turns out the second sheet was needed for a couple elements. They are all on it now.
Old 05-31-2026, 11:55 AM
Clear coated, cut and buffed.
Old 06-07-2026, 12:43 PM
The body has been mated to the chassis. Now it’s time for the final assembly.
It goes together a bit differently than other kits…
