Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 03-17-2026, 07:19 PM
macbubba macbubba is offline
Clutch won't dis-engage
Hi All, all of a sudden my clutch won't dis-engage the tranny. I pulled trans arm & all linkage to pedal & all look fine, there were no weird noises prior to this (snapping, breaking), any help would be appreciated.
Old 03-18-2026, 07:35 AM
maxwedge maxwedge is offline
A990 racer
Re: Clutch won't dis-engage
What vehicle?
Old 03-18-2026, 08:07 AM
alloro alloro is offline
I had this happen once with my 340 Duster. It turned out the pivot bracket had broken inside the bellhousing that the clutch arm attached to.
Old 03-18-2026, 10:47 AM
[quote=maxwedge;7241795]What vehicle?
Sorry, It is a `48 Ford with mechanical linkage.
Old 03-19-2026, 07:36 AM
A990 racer
When you step on the pedal does it have the normal resistance, or is it loose?
Old 03-19-2026, 12:02 PM
Feels Normal, regular pressure, Thanks.
Old 03-20-2026, 07:30 AM
A990 racer
Can you get someone to watch the clutch linkage movement, if everything moves as it should and the clutch is still engaged, gotta inside everything to see what's what
Old 03-20-2026, 11:15 AM
Hi Thanks, All linkage ok, guess I`ll have to get inside as you say. Thanks again. Any online parts houses that have new or used linkage/clutch parts?
Old 03-20-2026, 03:28 PM
A990 racer
Get it diagnosed for exactly what you need.
