Old 01-08-2026, 05:20 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Sunoco Ferrari 512 LeMans 1971
This is a Hostaro 1/43rd scale resin and white metal kit.
The mold for the white metal wheels was wearing out when they were cast.
I machined the back sides to remove the extra material and open up the holes.
Old 01-17-2026, 12:37 PM
Re: Sunoco Ferrari 512 LeMans 1971
Once they were polished and painted I didn't think they looked acceptable (wheel at the top) so I designed a new set in CAD and printed them (center).
I milled a set of outer rims from aluminum and painted the raised silver detail. I have metal center nuts for them too.
Old 01-17-2026, 12:55 PM
Getting the wheels to fit in the wells took a good amount of grinding on the inside of the body and then shimming the axles. As nice as the casting looks on the outside there's all sorts of wonkiness on the inside. (The casting is dated 12-20-1984, so it's not a big surprise from a 41 year old kit.)
The Following User Says Thank You to Scale-Master For This Useful Post:
Raikkobin (03-20-2026)
Old 02-11-2026, 12:28 PM
FWIW... Same car, not repainted. Same camera, same settings.
My guess is the auto settings of the camera missed something the day before.
Old 03-13-2026, 01:45 PM
The original goal was to use the kit provided decals, but even with two coats of clear they were cracking during application. I was able to use some of them despite that issue, but I had to make some too. I used foil instead of the silver decals for the lower edges.
Old 03-20-2026, 11:32 PM
Raikkobin Raikkobin is offline
Nice work on a tough kit!
The Following User Says Thank You to Raikkobin For This Useful Post:
Scale-Master (04-01-2026)
Old 04-01-2026, 01:31 PM
I finally found the time to get back on this and I'm in the final stretch.
