Old 09-17-2025, 01:42 PM
half-fast half-fast is offline
1986 Fuel Tank Selector Valve
My 1986 C10 Silverado has dual fuel tanks. The OEM fuel tank selector valve (not the switch) has failed. The OEM valve has 1/4" fuel return lines. The replacement U7000, U7001, FV 5, 8F1312, FSV2A/K, 42-159 all have 5/16" return line nipples. The associated steel lines are 1/4". The above valves cannot be installed in place of the OEM valve. Is there a correct replacement fuel tank selector valve that has 1/4" fuel return lines to match the OEM valve?
Reference: GM#12336290, 12336291
Old 09-24-2025, 07:19 AM
Re: 1986 Fuel Tank Selector Valve
I went to a Chevy dealership (Hendricks) and spent about 15 minutes working with a parts guy and came up with the following: The OEM part number for the valve with the 3/8"-1/4" nipples is 14029228 which is discontinued. If you can't find one of these you have to re-engineer the selector valve. The space is very limited so good luck with that. Pollak made a replacement but that is also discontinued. I don't know what the Pollak part number is but I purchased one off Ebay. Apparently, these are unobtanium and are solid gold- based on the price. Even so, my time is worth money and I chose to pass on the re-engineering approach.
