Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-16-2025, 11:26 AM
Daveone23 Daveone23 is offline
2019 trax overheating
I replaced the thermostat, radiator
Cap and its blowing the radiator
Cap. Water pump is not leaking.
Head gasket test looks ok. Fan is
Working. What
Could be causing this.
Old 08-16-2025, 12:03 PM
maxwedge maxwedge is offline
A990 racer
Re: 2019 trax overheating
Welcome to AF. Ok, how do you know the hd gasket is ok? Start the engine from cold, wait one minute and see if the radiator hoses are pressurized.
Old 08-16-2025, 07:36 PM
I used th CO gas tester. Its very sensitive.
Old 08-17-2025, 06:57 AM
A990 racer
Ok, I've used that test also, but not every head gasket issue involves combustion gasses. Plugs show any sign of coolant contamination? As I suggested, does the radiator hose get pressurized right after a cold start?
Old 08-17-2025, 12:48 PM
Harder then when cold but not hard. Even when super hot hoses are not hard. I pressurized the system to 20psi and it holds.
Old 08-17-2025, 01:51 PM
A990 racer
Using an infrared thermometer, check the temp differences between the radiator hoses, an efficient radiator should have at least 20 degees difference. Also look for cool areas in the core. Of course make sure all the air is bled out of the system.
Old 08-17-2025, 06:36 PM
This car has no bleed screw. I ran it for a while with
The overflow cap off hoping it would bleed off.
