Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-06-2025, 07:51 PM
suznicole suznicole is offline
Small evap leak
2001 Camry 4 cylinder replaced canister and solenoids and gas cap. Check engine light still coming on. How can find this problem? Any ideas what it could be?
Old 08-06-2025, 10:05 PM
aleekat aleekat is offline
Re: Small evap leak
Post the actually codes.
Post back, that's what makes Forums Work.
Old 11-30-2025, 11:34 PM
Repulsive_War_018 Repulsive_War_018 is offline
Re: Small evap leak
Classic EVAP headache on the '01 Camry; those small leaks can be sneaky even after swapping the usual suspects.
Since you've already done the canister, solenoids, and cap, next up: smoke test the system (rent a machine from AutoZone for cheap) to spot the exact leak;often it's a cracked hose to the intake manifold or a faulty purge valve diaphragm that doesn't show on visual inspection.
Pull the exact DTC (P0440? P0442?) with a scanner if you haven't; that'll narrow it. The factory service manual has the full EVAP schematic and pressure test procedure (section EC-50 or so) that makes it foolproof.
Hang in there, you'll chase it down quick! What code is it throwing?
