Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-26-2025, 12:50 PM
crcook84 crcook84 is offline
A/F & O2 sensor reader for Toyota
So, I've had a 420 code on my Toyota for a while. Before, I was using Scotty Kilmer's advice of pouring laquer thinner in the gas tank to clean out the Cat for another 6 to 12 months. That helped me for a few years. But, that hasn't been helping me for the last 3 months. So, I'm hoping to find a tool that will allow me to read the sensors in the Cat system to determine where the problem is. I've read that, instead of 2 oxygen sensors, my car might have an air-fuel sensor upstream and an oxygen sensor downstream. However, it looks like not all ODB2 readers can read one or both sensors. So, does anyone have a lead on an ODB2 reader that can read both the A/F and O2 sensors on a Toyota
I have a 2009 Toyota Camry 2.4L 2362CC 2AZ-FE
Old 06-26-2025, 05:04 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: A/F & O2 sensor reader for Toyota
Kilmer is a hack. Don't listen to anything he says.
Your car likely has a precat o2 and a post cat o2. The post cat o2, or the cat itself is going to be the one at fault for a P0420. P0420 has to do with catalyst efficiency, and not with the air/fuel mixture.
Old 06-26-2025, 06:33 PM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: A/F & O2 sensor reader for Toyota
Correct
Old 06-26-2025, 07:22 PM
Ok. Well, I managed to take the post cat o2 off and cleaned it with carb cleaner. Not sure if that will do anything. If not, then I guess replacing that will be the next cheapest thing apart from replacing the Cat.
Tags
odb2 , reader , sensor
