Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 06-03-2025, 06:45 AM
smonaldo smonaldo is offline
Annoying Check engine light P219A
I purchased a 2017 Yukon Denali in August of 2024 with 58,000 miles on it. I also got the extended warranty.
In September they had to replace the lifters. In February of 2025, the lifters went again. They wound up replacing the engine with a long block. Since then I have been getting a constant check engine light relating to the Fuel management system, The have replaced all the injectors, the high pressure fuel pump, and the fuel rails. The last go around (Friday) they updated the ECM firmware. 30 hours later.....cruising at 55, check engine. P219A
I am lost with any more ideas. All mechanical components have been replaced, any suggestions? When the light comes on the engine does idle a little rough.
Old 07-06-2025, 10:47 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Annoying Check engine light P219A
There are three different injectors with different flow rates for this engine. If an incorrect injector or injectors are installed, this code will result.
Take it back to the shop that replaced the injectors and make sure they put the right ones in!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
