Old 04-11-2025, 08:36 AM
waterkeeper03 waterkeeper03 is offline
Working it out
Rough Idle and no MAF
My car has been exibiting symptoms of inconsistent idle for the last month. a sudden single drop in RPM, or 3-4 quick burst of drop in RPM. always at Idle. it can happen twice in a commute, or never on 2 hours drive.
The EGR was recently replaced, but I still concerned it may be bad, I have unplugged it to see if the problem persist.
I intended to clean the MAF when i got home last night, only to find it doesn't have one.
anywhere else to look or point?
2016 Limited 3.5
1963.5 Galaxie 427 5spd .. 2016 Taurus Limited 3.5 .. 2011 Jetta Sportwagen TDI
Old 04-11-2025, 10:11 AM
maxwedge maxwedge is offline
A990 racer
Re: Rough Idle and no MAF
Clean the throttle body?
Old 05-08-2025, 09:10 AM
Working it out
TB is cleaned. problem persist.
I typed wrong in last post. The canister purge valve (CPV)was replaced (not egr)
When i unplug the CPV, the rough idle goes away. comes back when plugged.
i replaced the CPV with another new one, problem comes back.
Check engine comes on when the CPV is unplugged and goes away when plugged back after the cycle commences so i assume it's working but causing an issue elsewhere.
Old 06-04-2025, 03:31 PM
Working it out
OK so the problem has gone away after running super premium fuel and Lucas fuel additive for 2 tanks. the problem comes back on a tank of Regular fuel, but goes away on super premium(no additive).
Plugs are less than 10k old. should i be considering coil packs or injectors or some other area?
Old 06-04-2025, 03:55 PM
A990 racer
What codes are you getting, fuel octane should not be causing what you describe. If injector clean helps, that could indicate an injector issue. This all guesswork.
Old 06-19-2025, 03:55 PM
Working it out
no codes... "all guesswork" is right... i was hoping somebody had an educated guess based on my only lead, the canister purge valve.
Old 07-06-2025, 10:26 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The 2016 Taurus most definitely has a MAF sensor. Look near the airbox. Two Torx head screws hold it in place.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
