| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
Solar Productions Porsche 908/2 and "McQueen" Porsche 908/2
These models are the same car at two different times in its life (Chassis #022). Before it was the dark blue #29 Solar Productions camera car for the movie Le Mans in the 1970 24 Hours of Le Mans driven by Jonathon Williams and Herbert Linge, it was the white #48 car at the 1970 12 Hours of Sebring driven by Peter Revson and Steve McQueen to second place.
About this time last year I started building three Trans Am Camaros at the same time. It turned out to be a lot more work than I expected, yet here I am again doing something similar. With a little luck I'll have these two done by the next 24 Hours of Le Mans. 1/43rd scale Starter resin kits. The basic clean-up and scribing have been done and the brass winglets have been fitted to them. ![]() The rear frame is PE brass in both kits, but not the same configuration. The one for the Solar camera car is on the right. It was very fragile so I soldered it up for strength. The other one seemed to be made from a much stiffer brass even though they are both the same thickness. ![]() The roll bars are bent from wire provided in the kits. I could not get solder to work with them so I used CA to hold the two pieces of each one together.
Re: Solar Productions Porsche 908/2 and "McQueen" Porsche 908/2
The last few brass parts were added before priming and painting the bodies. TS-26 Pure White for the 48 car and for the 29 car I used an enamel blue I mixed for the Sunoco Camaro that I didn't care for at the time as a starting point, but I tinted it with TS-72 Clear Blue to look more like the Porsche photos I have.
The wheels are done. Metal rims and center nuts, resin spokes. I used LP-40 Metallic Black followed by clear flat.
Interior/engine/chassis for them. Not a lot of detail. But not a lot can be seen either.
While I was prepared for the decals to be less than user friendly, I was pleasantly surprised how well the first one worked. I used a lot of decal solvent and it held together and stretched very well. It's also even more opaque than I expected.
The kit decals and the shape of the body are not exactly spot-on compared to the photos of the real car, but then it is a Starter kit…
I used what was provided and tried to make them fit as well as possible. All of the decals worked quite well. Let's hope the #48 car's decals are as user friendly. ![]()
Another pleasant surprise, the decals for the McQueen car were good too, although a few of them split partly due to them being such delicate pinstripes. I'm sure age was a contributing factor as well. One of them was missing some ink so I cut a sliver of blue decal material and made a little patch.
Decals look good. You almost forget how small these cars really are
I'm building a 1/35th scale D9 bulldozer along side, it's reminding me how small they are...
Both bodies have been clear coated and will cure for a while.
The #48 is almost done, just a handful of small parts to add.
The #29 is almost done, just a handful of small parts to add.
Stunning models!
Thank you Potsie!
