Go Back   Automotive Forums Car Chat > Cars in General
Old 01-22-2025, 08:54 PM
jeffmorris jeffmorris is offline
Turn signals and headlights
I saw a new car whose driver used left turn signal. The right headlight is on and the left headlight is off while the left turn signal is blinking. I don't know the make and model of the car. It was daytime and not nighttime. Is the left headlight supposed to be on while the left turn signal is blinking?
Old 01-22-2025, 09:23 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Turn signals and headlights
That sounds like daytime running lights (DRLs) rather than headlights. Most newer vehicles with LED strip DRLs turn off the white LED DRL when the turn signal on that side is activated.
-Rod
Old 01-23-2025, 08:05 AM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: Turn signals and headlights
Correct shorod, I see that on my wife's new Equinox.
Old 05-22-2025, 03:51 AM
ottomotive ottomotive is offline
Hey, I once saw a ride do the same trick. Left blinker flashing while that side headlight sat dark. In my experience, when I tap my left turn signal, both daytime running lights stay on while the indicator blinks. But I’ve learned some car models dim the DRL on the signaling side to make the blinker pop like a built-in heads-up to oncoming traffic. If it feels funky or uneven, it might be a DRL circuit hiccup or a loose bulb socket. To me, both lights should stay lit.
Old 05-29-2025, 10:48 PM
aleekat aleekat is offline
Lots of the newer cars do this. Normal.
Post back, that's what makes Forums Work.
Old 07-11-2025, 06:17 AM
OliviaS OliviaS is offline
That actually sounds pretty normal for some newer vehicles. Many cars now have daytime running lights (DRLs) that double as turn signals. When the signal is activated, the DRL on that side often turns off so the blinking is more visible. So in your case, the left DRL turned off while the left turn signal blinked, and the right DRL stayed on. Totally expected behavior!
Wrenching. Learning. Enjoying the drive.
Proud truck owner | Diesel fan | Always up for a good mod discussion
Old 07-27-2025, 10:42 AM
shorod's Avatar
SHO No Mo
Originally Posted by BeirBrook View Post
Nope, some cars are designed to dim or turn off the headlight on the side that's signaling so the blinking turn signal is easier to see in daylight.
I don't think that's quite accurate. It's not the headlight that's turning off, but rather the daytime running light. I suppose it's possible that maybe some countries allow the headlight to turn off, but what I've encountered, it's only been the DRL.
-Rod
Old 07-27-2025, 07:17 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool Re: Turn signals and headlights
-Rod
I guess some experimentation, with a camera phone filming such equipped cars, will confirm one way or the other.
Longacre Racing...
The BEST Tire Gauges 1 AU from the Sun!
Old 07-29-2025, 10:24 AM
It's DRL, at night the headlight does not turn off.
