Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 01-03-2025, 06:07 PM
Bro Harding Bro Harding is offline
Replaced battery car won’t start
Lights appear on the dashboard but the engine does nothing
Old 01-03-2025, 07:04 PM
aleekat aleekat is online now
Re: Replaced battery car won’t start
Year/model? Did it start before you replaced the battery? Try moving your gear shifter through the gears. Try starting in neutral.
Post back, that's what makes Forums Work.
Old 01-03-2025, 08:02 PM
I purchased the car yesterday. I towed it home on a tow dolly. I failed to turn off the ignition. This morning I jump started it and went to the gas station. I removed the battery to charge it. When I installed a temp battery so I could get it inspected today it would not start.
But Yes. I went through each gear, tried starting in neutral and park. I held the gear shift in park also.
Old 01-03-2025, 08:03 PM
07 ford taurus
Old 01-03-2025, 08:10 PM
You posed this in the Toyota forum. Post in Taurus. Your temp battery may be the problem.
Old 01-03-2025, 09:17 PM
My fault. Its a Toyota Camry
Old 01-03-2025, 10:36 PM
Post it in the Camry section with ALL the info if you want help. You bought a non-running vehicle. You need more diagnosis for help.
The Following User Says Thank You to aleekat For This Useful Post:
Stealthee (01-04-2025)
