Old 11-22-2024, 06:28 AM
pinto12 pinto12 is offline
Battery voltage
Hi
The car wouldn't start anymore with the 3.5 year old battery on my weekend vehicle (I noticed engine turn over was getting weaker over time). Naturally I though time to replace. Checking voltage with a multimeter I was surprised to read 12.3V. Charged at home to 12.85 & left disconnected. A day after it's 12.55 and a day after 12.52.
I'm not knowledgeable re car batteries but does this make sense?
Thanks
Old 11-22-2024, 07:07 AM
maxwedge maxwedge is offline
A990 racer
Re: Battery voltage
Welcome to AF. Any temp changes after charging ? Give it a couple of days, see where it goes to. Possible this battery just won't hold a charge.
Old 11-22-2024, 01:45 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Battery voltage
It's possible for the voltage to read acceptable when using a multimeter since they, by design, do not load the circuit they are measuring. So the "old" battery might have voltage, but not capacity. You should try monitoring what the voltage drops down to when trying to start the car.
Modern cars require pretty robust batteries, and for the past 10 or so years, if you're able to get more than 3 years out of battery, at least here in the Midwest, you're doing well. Locations where the temperature is a bit milder and more consistent batteries might last longer.
-Rod
Old 04-06-2025, 03:50 PM
grouseman grouseman is offline
Re: Battery voltage
I would suggest you load test the battery. A battery voltage may look good but under the load of starting the cold cranking amps are too low. You can buy a battery tester at Harbor Freight for $18 that will put a load on the battery similar to starting the engine. My thought anyway. Grouseman
CEN-TECH
100 Amp, 6/12V Battery Load Tester
(2141)
$17.99
