Old 10-30-2024, 09:52 AM
T6Davis2 T6Davis2 is offline
Removing Broken Tip in FuseBox
Hello,
My lights stopped working on my wife's car, 2013 Ford Fiesta, and after checking's bulbs and connections I found that a relay had corroded in the fusebox and now there is a tip stuck in the fuse box, it is flush with the box and there is no area to pull it out with pliers or tweezers. Any suggestions, I thought about trying to disconnect the fuse box and see if I can push at it from the underside but not sure what exactly that would entail.
Thanks for your assistance.
Old 10-30-2024, 08:50 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Removing Broken Tip in FuseBox
Unfortunately, if the contact for the relay corroded bad enough that it broke off, you likely had a poor connection with that relay terminal, and the terminals have overheated and weakened now. So even if you were to get the broken piece out, you would not get a new relay to make a good connection and would have the same issue in short time.
You might want to check NHTSA's website to see if maybe there is a recall for this existing on your car due to the safety risk this could provide (both from visibility and from possible fire risk from the poor connection), and if not, your best bet might be to source a replacement fuse box from a salvage yard or the dealership.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
T6Davis2 (10-31-2024)
Tags
fusebox , repair
