Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-09-2024, 02:18 PM
carl80 carl80 is offline
98 Camry 2.2l no start when cold but cranks over
My daughter's 98 Camry drove fine one day, the next morning when she goes to start it, it would start for 3 to 5 seconds and shut off. After trying to start it several more times it would quit run for those few seconds and just crank. My first thought was possible fuel pump. I pulled the seat out and had her crank it while I went to listen to the pump, but it just started and ran just fine. I could shut it off and started again I drove it around with no problems. The next morning I try to start it and it would not start. I was thinking maybe the fuel pump was faulty and I replaced that. It did not change anything. After about 30 minutes of trying I got it to start again I was able to drive the car back to my house so I can work on it and it would start and drive just fine all day. This morning, won't start again just cranks over. I tried unplugging the map sensor to see if that would change anything. And I removed the intake hose and sprayed cleaner on the little port In front of the air valve to see if that would fix anything.
I don't know where to go next
Old 10-09-2024, 03:11 PM
aleekat aleekat is offline
Re: 98 Camry 2.2l no start when cold but cranks over
If you tried the spray and it didn't start. Sounds like no spark.
Post back, that's what makes Forums Work.
