Go Back   Automotive Forums Car Chat > Chevrolet > Spark
Old 10-09-2024, 10:01 AM
ice101 ice101 is offline
2013 Chevy Spark intermittently no starts
I have a 2013 Chevy Spark that was showing symptoms of the starter starting to go bad. You would turn the key on, all the dash light come on, but you go to start the car, and nothing would happen, not even a clicking noise. Tested the battery, battery is good, replaced relay with a new relay and it did the same thing. Replaced the starter and the car continues to do the same thing, intermittently, sometimes it starts, sometimes it doesn't. I was thinking it could be a bad ignition. Is there any other trouble shooting things I should do to figure out this perplexing problem?
Old 10-09-2024, 01:58 PM
aleekat aleekat is offline
Re: 2013 Chevy Spark intermittently no starts
If you jump the starter and it starts. Suspect neutral safety switch or ignition switch. Try moving gear selector through the ranges. Try starting in neutral.
Post back, that's what makes Forums Work.
Old 10-09-2024, 03:42 PM
I jumped the starter and it engages no problem. I just want to make sure I understand what you are saying, I should try to start the car while it is in gear beginning with neutral? If it's a bad neutral safety switch the car will start?
Old 10-09-2024, 04:21 PM
It should start in neutral.
The Following User Says Thank You to aleekat For This Useful Post:
Stealthee (10-10-2024)
Old 10-10-2024, 08:46 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
This. It's a test to see if maybe the car either is fully going into park, or thinks it's not in park. The car should start in nuetral, just like it does in park.
Tags
2013 , chevy , ignition , spark
