Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-06-2003, 03:03 PM
puckmanc84 puckmanc84 is offline
Send a message via AIM to puckmanc84
broken speedometer
hi, my brother just bought a 1989 maxima with about 120k miles on it about a month ago. the car worked great and is very mechanicly sound but about a week ago the speedometer just stopped working and so he brought the car to me to see if i can fix it. i was wondering what the easiest way to take off the dash is. i have never worked on a nissan before and want to know if there are any things that i should be concerned with in the dash when i begin this project? thanks a lot!!
Old 07-06-2003, 05:20 PM
TravCav TravCav is offline
Send a message via AIM to TravCav
Wow, japanese cars aren't simple dude, and the odds of getting them back together exactly are slim, i would recommend just taking it in to the dealer, and if you don't like their price offer, i could get you an aftermarket spedometer and hook it up for you, or i could tell you how, or i could refer you to a couple of friends of mine, whichever you prefer, and in all, definitely not to say that you're not capable, it's just that nissan's are so nice...
Old 07-06-2003, 07:14 PM
speedometer update
I completely took apart the dash board and was able to take out the speedometer and much to my dismay found out that it was electric and computerized even though it had a needle. Having most of my car experience with older American cars I expected a mechanical speedometer running with a cable from the transmission. If anyone knows where the problem might lie, since it’s not with the speedometer in the dashboard that would be a great help. thanks again.
Old 07-07-2003, 08:06 PM
Paonessa Paonessa is offline
is it all the guages or is it just the speedo? check your fuses, i know there's a 10a that runs your dash. maybe #13.
Old 07-07-2003, 08:22 PM
it is just the speedometer and the odometer that are not working the tach and the other gauges still work correctly. i checked the fuses for the dash and they all were still good. is there like a speed sensor or something to that effect that can go on these cars (something uder the hood)?
Old 07-17-2003, 08:49 PM
mrmaxima97 mrmaxima97 is offline
Send a message via AIM to mrmaxima97
There is a speed sensor, but it most likely won't fix the problem. I have the same issue with my baby I have to get a new cluster.
Mods:
KYB AGXs, Maxspeed springs, Injen CAI, Budget Y, Clears, FSTB, RSB
Future:
White Rims, Custom interior, Stillen body kit
Old 07-17-2003, 10:27 PM
KinKyGoOsE KinKyGoOsE is offline
Send a message via AIM to KinKyGoOsE
you might have to buy a new guage cluster =/
Seen this b4 and thats what they had to do. Resale goes to shit cuz of the false reading on the OD and whatnot.
ANd you have to register with the DMV with the incident so you dont get caught for fraud if you sell the car.
Old 07-20-2003, 07:02 PM
tdaily tdaily is offline
Sounds like the cluster to me. Junk yard find, or you may find one on ebay. Figure on $35-$60 depending on how much of a hurry you're in and how long you're willing to wait on a better deal that $60.
Tdaily
Old 07-22-2003, 04:55 PM
keith_u's Avatar
keith_u keith_u is offline
Send a message via Yahoo to keith_u
I had mine stop too in my 87 but it is digital and all i did was put in a new speed sensor and it has been fine ever since.
Old 07-24-2003, 03:31 PM
bluesox bluesox is offline
I got the same problem with my 91 maxima. Could anyone please tell me where's the speed sensor located?
Old 07-25-2003, 10:28 AM
keith_u's Avatar
I know on my 87 it is on the fire wall under the hood right in the center.A little round thing with a cable going in one side from the tranny and a set of wires out the other side to the dash.It may be diffrent on your 91 tho.
Old 10-12-2003, 12:31 AM
lkly2l lkly2l is offline
Speedometer problem
My experience: I have an intermitten speedometer problem that I traced back to the speed sensor. I have taken the instrument cluster apart and found no faults. When I examined the speed sensor (the vertical cylinder located next to the oil filter on my automatic transmission) I found that the two wire leads were in fact hanging by a single wire strand and ready to fall off. This was the cause of the intermitten signal. The speed sensor is held in place by a single 10 mm hex bolt and can be removed straight out of its socket by twisting back and forth. Take care not to let dirt fall into socket (ie, clean the area before removing). To test the part, hook up a voltmeter to the leads set on AC voltage. Spin the speed sensor gear and you should see about 0-0.5 volts. (I actually got about 0.8 V on mine first spin) A new replacement speed sensor from Nissan is about $150 here in Pittsburgh. A new instrument cluster is about $225 and requires odometer reading verification so that Nissan can preset your odometer to your current reading. You'll also need your VIN number to verify. I would like to know if others have similar experience. Thanks.
Old 03-05-2004, 03:13 AM
Mike73 Mike73 is offline
Re: broken speedometer
Keith I have a 87 also where did you get the speed sensor from and also where is it located. Not sure if it is the problem some times the speed odometer works and sometimes it dosen't. Thanks for any help.
Old 03-05-2004, 10:32 AM
keith_u's Avatar
Re: Re: broken speedometer
Mike I got mine from my parts car that I bought,but you can find them at a junk yard.If not you have to get them from the dealer(it is one of them dealer only parts)and there 350 bucks new.best bet is to look in the junk yard and hope that it is a good one.
Keith
Old 03-07-2004, 08:19 PM
Re: Re: Re: broken speedometer
Keith
Thanks for the info keith. Got one at the junk yard. and it works wow!! Now I get to do the CV joints fun!!!
