Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 07-14-2024, 04:13 PM
rollingthunder6 rollingthunder6 is offline
2014 honda civic air conditioning question
"bizarre" a/c behavior
2014 honda civic LX 1.8L engine, 117,000 miles
engine is running, vehicle stationary, hood up, ambient outside temperature 90degrees
PLENTY OF VERY COLD AIR INSIDE CAR AT THE VENTS at all times
pressure at low-side port wobbles a bit around 40 psi value
compressor turning, clutch engaged;
compressor clutch does not ever disengage during any of the following
and the condenser fan itself also turns continuously during all of the following :
shortly after engaging a/c from within the vehicle, here is what happens:
there a thumping/rumbling noise from the condenser fan area,
and a large blast of very hot air shoots out towards rear of engine;
the noise and air blast last for about 10 seconds; the both stop for about 10 seconds;
then both occur together again for 10 seconds; then off for about 10 seconds,
- over and over ; (after a couple minutes of this, i turn a/c off)
what is the cause of this periodic, repetitive, off-and-on rumbling noise and air blast
( i say again: the condenser fan does NOT stop-and-start during any of this) ?
(I've consulted the Haynes manual but nothing in there corresponds to anything quite like this)
thank you
