Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-06-2003, 02:27 PM
GQ244 GQ244 is offline
Coilovers or lowering springs?
I was wonderin wat would be better if i wanted to lower my car. i want to lower it about 2 inches. wat would be better to get coilovers or springs. Also which brand u reccommend (i.e. skunk 2, eibach springs)
G
Old 07-06-2003, 02:45 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Skunk2 coilovers
Old 07-06-2003, 02:49 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
definately coilovers especially if you live in an area where you will be using your car in winter (raise it back up in winter) also you can slam it at shows and such and raise it up off the ground for the drive home. basically they are alot more versatile and probly depending on what brand will improve your ride alot more than just springs.
by the way i kinda like Tein.
Old 07-06-2003, 03:11 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Are you guys talking about true full coilovers or just the cheap sleeve kind?
If you arent gonna get true coilovers, I would recommend getting springs, the cheap sleeve kind have been known to be crap.
Old 07-06-2003, 03:17 PM
knorwj's Avatar
yeah good point, i was talking about the true kind with the shock built right in, not the sleeve type.
Old 07-06-2003, 03:34 PM
B16EJ1's Avatar
How exactly do you mean? What experiences have you have with them? So if I bought Skunk2 coil-over sleeves and slapped them on some AGX adjustables or Tokiko's are they still crap? But anyways explain what exactly makes them crap. I don't understand your logic.
Old 07-06-2003, 03:48 PM
knorwj's Avatar
not exactly crap unless used with stock shocks, but the ones that come together are a little more reliable, they are engineered and tested to be used together and i just feel that even though more expensive it is the way to go
Old 07-06-2003, 03:51 PM
knorwj's Avatar
besides if you are spending the money on the sleeves and the shocks then you might as well buy ones that are made together. the Tein ones that i am getting come with adjustable shocks, and the adjustable coil spring for 750 , not bad i feel especially for such a good name
Old 07-06-2003, 03:55 PM
B16EJ1's Avatar
I completely agree but coilovers alone is not what makes the ride crap. It's people lowering too much. Springs and oem shocks are the same at killing oem shitty ass Civic struts. I've gone both routes with H&R springs and cheap ass coilovers and I'd still take coil-overs anyday. Adjusting ride height at any time is always a plus. Gas shocks will be needed any route you decide to take. Full coil-over kits are the best but Tokiko's and coil-overs will suffice.
Old 07-06-2003, 03:58 PM
B16EJ1's Avatar
I paid 300 for Tokico's and a 100 for coil-overs and have no complaint's. Eventually I plan to get a full coil-over kit but I am in no rush.
Old 07-08-2003, 06:58 PM
im confused?
ok guys so i guess coilovers are the best but u guys lost me with the whole true coilover thing. on modacar.com they show coilovers for like $1,000 isnt that overpriced? When i looked at the skunk 2 coilovers they were only around 300. Am i lookin at the cheap version or are they just much cheaper than the others.
Also where online can i find and buy the true skunk 2 coilovers? I'd appreciate someone to clear this up thanks
G
Old 07-08-2003, 07:07 PM
my fault
the skunk2 coilovers were on optauto.com not modacar. Sorry
G
Old 07-08-2003, 07:27 PM
One more thing
I found out wut u guys meant but i still got one questio if i were to get just the sleeve coilovers like the skunk 2's would the handling suffer?Or would it be just as good as stock?
G
Old 07-08-2003, 09:16 PM
Options Options is offline
Send a message via AIM to Options
Personally i would get the adjustable skunk 2 coil overs, if ne thing they would help handling, because they stiffen up the suspension.
Its not how fast you go it how fast you finish.
Second place is the first looser
Skunk2 Coil-overs
Aem 2 piece intake
Tanabe Exausht
Throttle Body coolant bypass
Apexi SAFC 2.
Skunk 2 cam gear.
ZEX dry nitrous system: currently 55 shot.
Best 1/4 Time:
16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray
Old 07-08-2003, 11:05 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
just to add my $0.02. I have number one sleeve coilovers, tokico's in the back and stock up front (the bvack struts needed to be replaced so i went ahead and got tockicos). I lowered it right above the tire all around. Rides great as long as you don't go down a road with hella potholes of course. my only problem now is camber
